Nobimmer 694 Report post Posted May 4, 2012 I am using a G260 on my m50. What clutch and pressure plate combos can I use? I'm guessing if I machine the m20 flywheel down a little bit it will work and be fine with the m20 starter motor? Or can I use a solid m50 flywheel with the g260 gearbox combo? I need something soon or I cant get the crank balanced. Cheers Ashkan Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 4, 2012 I am using a G260 on my m50. What clutch and pressure plate combos can I use? I'm guessing if I machine the m20 flywheel down a little bit it will work and be fine with the m20 starter motor? Or can I use a solid m50 flywheel with the g260 gearbox combo? I need something soon or I cant get the crank balanced. Cheers Ashkan i made a billet flywheel and used a ring gear off a v6 holden and fitted the bigger m30 clutch then use the 11 tooth pinion starter Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted May 4, 2012 I am using a G260 on my m50. What clutch and pressure plate combos can I use? I'm guessing if I machine the m20 flywheel down a little bit it will work and be fine with the m20 starter motor? Or can I use a solid m50 flywheel with the g260 gearbox combo? I need something soon or I cant get the crank balanced. Cheers Ashkan just use the m20 one and leighten it to about 6.5kg etc m50/m52 all came with yukky dual mass flywheels Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 4, 2012 knowing what your trying to do with the m50 the m20 is a waste of time and lighting flywheels isnt a smart thing to do if you like your feet and legs , plan ahead and you'll be better off in the long run. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 4, 2012 Just do what I did and make one out of billet. Here is what I did. http://www.bminfo.co.nz/?page_id=67 Make sure you have the whole lot balanced together afterwards. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 4, 2012 Just do what I did and make one out of billet. Here what I did. http://www.bminfo.co.nz/?page_id=67 Make sure you have the whole lot balanced together afterwards. +1 on that even if its made from mild steel its 1000 times safer than any cast flywheel thats been hacked up. Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted May 4, 2012 I used a m20 6.5kg flywheel and a carbon kevlar clutch with m20 starter. By the time you factor a higher through out bearing, new slave cyl and bolts it was around $1000+. I know on Trademe you can get a combo for around that price. Food for thought... Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted May 5, 2012 Sweet sorted cheers guys, and thanks Steve for the help throughout as always. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 5, 2012 Sweet sorted cheers guys, and thanks Steve for the help throughout as always. when your ready i want to go over your setup Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted May 6, 2012 Match your starter / clutch / fly to the g/box you're using. Quote Share this post Link to post Share on other sites
