yng_750
e39 540i rough running / idling
i have a 1998 e39 m62b44 non vanos 540i
did a good thousand kms of driving over the past weekend and after sitting for a day it seems to have developed a rough idle and has a small miss while driving. exhaust doesnt smoke or smell of fuel so possibly a mixture issue rather than complete miss
things checked so far in order of what i thought prudent
1. put injector cleaner in, no immediate difference
2. pulled engine covers, no oil in galleries and no arcs off coil packs at night. one coil pack is marked 2007 and is a different brand to the others, looks like its been quite hot but no smells.
3. cleaned AFM and ICV. no immediate change but havent run on a cold morning yet, as that is when its at its worst. Will update
Things to test.
4. Pull plugs (new plugs 9 months ago a per Service history) and check for discoloration that would indicate a bad coil or cracks in plug etc
5. investigate CCV valve. still not exactly sure where this is. back of the intake?? any guidance appreciated.
6. Get codes read, still trying to find a place in taupo for this, tossing up buying the cable from the UK.
7. Check for vacuum leaks or split hoses. going to attempt either gas or smoke test in a diy fashion.
any other ideas or guidence on up and coming test appreciated
will keep this updated and add pictures for others reference
pulled plugs
all look ok
cylinders 7 & 8 had a little oil on the plugs so i cleaned that up
still running the same
Just bought a code scanner tool so should know more by the end of the week
Ive just had this same problem. Turned out to be a coil pack. Didnt throw any error codes so had me stumped for a while.
Hope this helps
pulled plugs
all look ok
unplug one coil at a time while running to see if it makes it idle worse, if not that could be the faulty coil
a member in taupo has offered the use of his scan tool
i will use that first
if i cant see anything i will unplug the coils one at a time and see what happens
im guessing if i unplug them first then i will have an error code for each coilpack waiting for me
anyway its pissing down today and we all know coil packs and rain dont mix
Haha - where's your sense of adventure??? :P
judging by how it doesnt seem overly rough but just has a rough idle when dead cold and seems abit flat i was already thinking it could have one bank running a poor mixture
Turbolizard ran the codes for me this evening
main responses were
primary oxygen sensor for both banks
and misfire on cylinders 4, 6 and 8
the misfire codes are likely from me playing with the coil packs and cleaning the plugs which caused it to miss for a few mins
the cats do seem to get very hot very very quickly so quite possibly either blocked cats or my long drive has over heated them to the point of damaging the O2 sensors
we cleared the codes and nothing reappeared after 5 mins of idling so i will wait a week and re check it and see what happens
Edited by jason H
got the fuel tank down under 30km range then put half a tank of Z 95 octane in it
seems to be a marked improvement
maybe the bp 98 from hamilton was abit sh*t
still not prefect so i might catch up with mike later this week and re run thecodes
also i have bought a code reader but it has the OBD2 style plug
anyone know if i can get an adaptor to the round 20 pin in nz?
everything i can see online is EX uk
car seemed to be running very much better though not perfect
until tonight
drove home form work ok
moved car out of driveway and parked on road ok
went to drive to the pub and it has a masive misfire
judging by the absolute lack of power and on off pulsing in the exhaust it seems like a whole bank is misfiring
Coil packs etc and bone dry
if it is the rains fault could is possibly be water on exposed o2 sensor wiring?
could a dead o2 sensor completely kill a bank?
Might see if mike can run my codes agin
infuriating weather to try and fix a car in
until tonight
sounds more like faulty coils ,pretty common to go as they have a limited life , you might have a few that are failing
until tonight
I have a very similar issue with the 735 E38 here. It is idling very rough when cold. Our scanner shows the 02 sensor as being the main culprit. We have switched them from side to side and are going to see what happens. I will scan it again in the morning and see what shows.
95% of the time O2 sensor fault codes are the result of another problem....not the sensor
Like if a coil isn't firing and the rich mixture/unburnt fuel upsets the O2 sensor and puts it "out of range".
Lots and Lots of codes aren't the item the code is for... pain in the buttocks!
+1
dickhead of the day award goes to me who forgot to reinstall the coil pack covers and has water down the spark plug tubes on cyl 7 and 8
Good C... of the day award goes to mike aka turbolizard who re ran my codes and didnt laugh at me for such a amateur mistake
on the upside the only codes stored after a week of driving were for misfires on cyl 7 & 8 while wet so looks like everything else is running relatively well
Still thinking cats are bad
might plug a pressure gauge in and test the back pressure before the cats
I have received good help from others on this board for nothing but a word of thanks. Glad I could do my bit to help someone else in return...
dont spose a really generous word of thanks would earn me the chance to drive an m5???
on second thought the fear of dinging something that impressive would have me glued to 50 so maybe not haha
sorry, I should have said more, we had misfiring on one bank of cylinders as well. We replaced all the spark plugs, took out the 02 sensors, gave them a clean and it seems to have solved the issuer. The car is running and driving a lot smoother!
Use the BMW diagnostic software and do a smooth-running test
You'll see what cylinder is the culprit
The swap coils from suspect cylinder with a known good cylinder
My money is a faulty coil, the above test will easily confirm it
