varun1794 0 Report post Posted May 13, 2012 hey guys i just blew my diff on my e30 320i facelift witch has a m50b25 in it, wat do you guys reckon is my best coice for a diff ratio? im not sure what ratio my old one was and also i dont hav much more then 200 to spend on the diff so sadly i dont think a lsd would be a option either if anyone has a suitable diff for sale plz contact me Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 13, 2012 I have a 3.64:1 medium case for $250 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 13, 2012 which gearbox do you have. if you are using a e30 type box getrag 240 or 260 then something like a 3.46 3.64 3.73 should be ok if you are using a e36 gearbox getrag 250 or zf tyoe etc with the 1:1 top ratio then you want lower numbers like 3.15 3.23 3.46 etc i would say your orginal e30 diff would be something like 4.1 or3.91 etc should have a tag on the back of the diff i take it its a small case diff , the replacing it with another one the same size will be easy if you want to change it to amedium case diff which can handle the power better then you will need the medium case axles to match go to here to work out how many revs at speed etc http://members.dodo.com.au/~wawawa/revs.htm select your gearbox and diff ratio etc Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted May 13, 2012 sack/save up and get an LSD. an M50 in such a light car is lethal without one, especially given the way it is no doubt driven. noone puts an M50 in an E30 to drive like a nanna. if you cant afford to do a conversion properly, you shouldnt have done it in the first place Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 sack/save up and get an LSD. an M50 in such a light car is lethal without one, especially given the way it is no doubt driven. noone puts an M50 in an E30 to drive like a nanna. if you cant afford to do a conversion properly, you shouldnt have done it in the first place well considering iv blown my budget on the car and only just got everything running right i dont think its a good idea 2 pay 600 for a lsd if i just got offered a open for 250 aslkongas its in good condition Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 which gearbox do you have. if you are using a e30 type box getrag 240 or 260 then something like a 3.46 3.64 3.73 should be ok if you are using a e36 gearbox getrag 250 or zf tyoe etc with the 1:1 top ratio then you want lower numbers like 3.15 3.23 3.46 etc i would say your orginal e30 diff would be something like 4.1 or3.91 etc should have a tag on the back of the diff i take it its a small case diff , the replacing it with another one the same size will be easy if you want to change it to amedium case diff which can handle the power better then you will need the medium case axles to match go to here to work out how many revs at speed etc http://members.dodo.com.au/~wawawa/revs.htm select your gearbox and diff ratio etc wow thanks that just made my life alot easier haha yea i think its a 3.91 Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 I have a 3.64:1 medium case for $250 do u know how many ks on it by any chance? Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 if im correct a lower ratio would giv better top speed biut slower acceleration? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted May 13, 2012 if im correct a lower ratio would giv better top speed biut slower acceleration? yup Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 hmm i shopuld probably go for acceleration since im never gonna be hitting 200 kmph around here Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted May 13, 2012 hmm i shopuld probably go for acceleration since im never gonna be hitting 200 kmph around here i had a 3.67 (LSD) in my M52B28 E30. i would have gone for a 3.91 (i think? 3.9x anyways). you probably have something around there now so you might feel dissapointed with a taller one. though your fuel economy would increase Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 lucky you iv always wanted a m52 haha well im still kinda lost with the ratios a bit n hav no clue wats goin on with the small and medium case stuff so ill do a bit of reaserch n then read this post again haha might understand it better thanks 4 the help everyone Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted May 13, 2012 lucky you iv always wanted a m52 haha well im still kinda lost with the ratios a bit n hav no clue wats goin on with the small and medium case stuff so ill do a bit of reaserch n then read this post again haha might understand it better thanks 4 the help everyone lots of people tell you that the medium and small case diffs arent interchangable, however i went from a small case to a medium case when i still had my M20 and didnt have to swap axels or driveshafts etc. aparently im the only one that didnt have to change them, not sure why. mind you i used E30 parts, and E30 medium cases might be hard to find and people use E34/E28 medium cases? dunno Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 13, 2012 choose the revs you are happy with at say 100km/h anything other 2800rpm is getting pretty buzzy . if you want a race car then 3500rpm etc is ok my 328i with 5spd 1:1 top does about 2650rpm at 100km/h so which gearbox are you using?? Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 13, 2012 choose the revs you are happy with at say 100km/h anything other 2800rpm is getting pretty buzzy . if you want a race car then 3500rpm etc is ok my 328i with 5spd 1:1 top does about 2650rpm at 100km/h so which gearbox are you using?? hey mate im using a getrag 240 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 13, 2012 hey mate im using a getrag 240ok so a 3.73 will give you 2600rpm at 100km/h or 3.64 2550rpm 100k's 3.91 2750rpm at 100k's Quote Share this post Link to post Share on other sites
varun1794 0 Report post Posted May 15, 2012 ok so a 3.73 will give you 2600rpm at 100km/h or 3.64 2550rpm 100k's 3.91 2750rpm at 100k's will it be a big sacrifise on accelerration say fom a 3.91 to a 3.64 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 15, 2012 Bugger all, work it out from the numbers:- Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted May 15, 2012 when i swapped from a small to medium case, it bolted straight in, was quite easy really. and you will feal the differance between those ratios, not sure how much but you will if i were you i would leave the car off the road for a couple weeks and save up for an lsd i used to swap from 4.1 to a 4.45 when i had my 1.8 engine and that was a noticable change, now im running a 3.25 lsd with the m52 and its WAY!!! to long for my liking Quote Share this post Link to post Share on other sites
