krsmith 0 Report post Posted May 27, 2012 I am new to Bimmersport and BMW's. I have just bought a Japanese 550i Touring (2006 E61) and annoyingly I could not convince the yard to convert the idrive to NZ. I am sure these questions have been asked a million times before and apologies up front for rehashing what is most likely old ground, however, from my initial research, it appears the conversion can actually be done in phases i.e. convert the radio (i read a guide, but not sure if it works with a E61). What about the satnav and phone? Can i simply get a NZ nav DVD to load up for NZ maps? Is there a simple technique for the bluetooth/phone interface? There appears to be a lot of cowboys out there who want to charge 2 arms and a kidney for doing the conversion and to be honest I cant see that it should be that tricky. Appreciate your feedback. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted May 27, 2012 Hi Kelly, not up with the i drive stuff but you could contact Grant ie Hotwire, Josh ie Hybrid or the sponsors of this section Car Entertainment Solutions also Jochen who pops in from time to time. Best of luck 1 Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 27, 2012 i'm not down with idrive yet sorry. Haven't had any vehicles to mess with. Remning / Car Entertainment Solutions is your best bet. He did my friends 6 series conversion. Not sure if hotwire does idrive either ? PS Mandatory pics of your car in the showroom please Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted May 28, 2012 Radio can be done via coding (about $300 to get someone to do it for you) its not simple and the equipment to do it will cost you more than $300 so dont bother unless you plan to do lots of cars. DO NOT USE A BAND EXPANDER THESE ARE S***. You will either have the CCC or new CIC system (i think yours will be CCC) CCC is the one with 1 or 2 buttons by the idrive wheel and CIC has 7? buttons around the wheel. CCC Nav works off a DVD/CD for the NAV, the disc itself is rather easy to obtain (can use an australian one as it contains NZ and AU maps) but for the Nav to work in NZ it will require a complete CCC computer replacement and recoding, this would run you around 2k+ there is NO way around this do not let anyone trick you into thinking its just a map CD its most definitely NOT. CIC Nav is harddrive based which requires the maps to be loaded to the internal hard drive and the FSC? code which is specific to the VIN of the car to be registered (i dont know the pricing on this but im pretty sure being an '06 your CCC anyway) note im pretty sure this would require CIC unit replacement and coding. Phone, depends what is in there now? if its a actual phone handset then its throw away it won't work in NZ. If its bluetooth (almost all japs seem to lack this, idk why) then you should be good to go just pair your phone. it is posible to retrofit bluetooth (if you have nothing or you have a jap phone) but its not cheap and requires hardware (new TCU) and coding. this is also in the 1-2k mark as far as i am aware. I have the factory bluetooth (nz new) i can honestly say its the best handsfree i've ever owned or used. absolutely perfect quality, sounds just as good as talking on the handset itself if not better, the system pulls your address book to the idrive, pairs flawlessly every time you put you key in and also displays your reception on the idrive screen. 1 Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted May 28, 2012 (edited) Alternative is to wait for the dynavin http://www.dynavin.com/news/news20120320.php Edited May 28, 2012 by rogan Quote Share this post Link to post Share on other sites
krsmith 0 Report post Posted May 28, 2012 Radio can be done via coding (about $300 to get someone to do it for you) its not simple and the equipment to do it will cost you more than $300 so dont bother unless you plan to do lots of cars. DO NOT USE A BAND EXPANDER THESE ARE S***. You will either have the CCC or new CIC system (i think yours will be CCC) CCC is the one with 1 or 2 buttons by the idrive wheel and CIC has 7? buttons around the wheel. CCC Nav works off a DVD/CD for the NAV, the disc itself is rather easy to obtain (can use an australian one as it contains NZ and AU maps) but for the Nav to work in NZ it will require a complete CCC computer replacement and recoding, this would run you around 2k+ there is NO way around this do not let anyone trick you into thinking its just a map CD its most definitely NOT. CIC Nav is harddrive based which requires the maps to be loaded to the internal hard drive and the FSC? code which is specific to the VIN of the car to be registered (i dont know the pricing on this but im pretty sure being an '06 your CCC anyway) note im pretty sure this would require CIC unit replacement and coding. Phone, depends what is in there now? if its a actual phone handset then its throw away it won't work in NZ. If its bluetooth (almost all japs seem to lack this, idk why) then you should be good to go just pair your phone. it is posible to retrofit bluetooth (if you have nothing or you have a jap phone) but its not cheap and requires hardware (new TCU) and coding. this is also in the 1-2k mark as far as i am aware. I have the factory bluetooth (nz new) i can honestly say its the best handsfree i've ever owned or used. absolutely perfect quality, sounds just as good as talking on the handset itself if not better, the system pulls your address book to the idrive, pairs flawlessly every time you put you key in and also displays your reception on the idrive screen. Thanks all for feedback. Looks like I'll need to pay a visit to a specialist - i have no intention of installing a band expander as they are crap. I had noted a post from Jochen stating that the radio can be converted following a few steps, however this is possibly not for an E61?? I'll check out the phone/bluetooth (I haven't picked up the car yet, just preempting projects - my wife doesn't understand!!). The idrive unit has 2 buttons so must be a CCC - sounds like I am in for some serious $$$$ to rectify the satnav problem. The car yard people reckoned the complete idrive can be converted to NZ for around $1,500 - $2,000 - does this sound realistic? Cheers Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted May 28, 2012 SWauto prices http://swautomotive.co.nz/product/oemt%20_IN.pdf so nav/radio using second hand unit 2k. (replacing the unit for nav negates the need to recode the radio from jap as this is done when you convert the nav). conversion on the old e39 system is 800-1500 depending on what you do and where the parts come from. the button pressing process cannot be used on idrive systems. Quote Share this post Link to post Share on other sites
krsmith 0 Report post Posted May 28, 2012 SWauto prices http://swautomotive.co.nz/product/oemt%20_IN.pdf so nav/radio using second hand unit 2k. (replacing the unit for nav negates the need to recode the radio from jap as this is done when you convert the nav). conversion on the old e39 system is 800-1500 depending on what you do and where the parts come from. the button pressing process cannot be used on idrive systems. Thanks Matt. Will follow up with SW Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted May 29, 2012 $1580 for a reversing camera !! For that price it better be handmade by naked vestal virgins and hand delivered by the Queen's butler. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted May 29, 2012 $1580 for a reversing camera !! For that price it better be handmade by naked vestal virgins and hand delivered by the Queen's butler. it is expensive but thats because there is more to it than adding a webcam to the bootlid. imo dont think its necessary if you have parking sensors Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted May 31, 2012 The price list is too old, I haven't got time to update it yet, All prices in there are dropped. Navigation conversion is now $1550 Bluetooth is now $949 BMW 6FL, 644 Bluetooth, ipod, usb retrofit for idrive car from $1499 Reversing camera for idrive car is $1099 (sedan) $1199 (wagon) CIC retrofit is also available. Now we can do BMW OEM combox 6NR, Internet, iPod video on CIC car. For UK import BMW, We can convert your CIC HDD map to NZ for $450. this apply to all E or F chasiss. BMW retrofit need a lot of knowledge about coding programming, also some special tools to do such thing. We can do many things that BMW dealer can't as we have more knowledge and constantly developing new solutions for new BMWs. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted June 2, 2012 The price list is too old, I haven't got time to update it yet, All prices in there are dropped. Navigation conversion is now $1550 Bluetooth is now $949 BMW 6FL, 644 Bluetooth, ipod, usb retrofit for idrive car from $1499 Reversing camera for idrive car is $1099 (sedan) $1199 (wagon) CIC retrofit is also available. Now we can do BMW OEM combox 6NR, Internet, iPod video on CIC car. For UK import BMW, We can convert your CIC HDD map to NZ for $450. this apply to all E or F chasiss. BMW retrofit need a lot of knowledge about coding programming, also some special tools to do such thing. We can do many things that BMW dealer can't as we have more knowledge and constantly developing new solutions for new BMWs. looking forward to a digital tv tuner being on that list. Quote Share this post Link to post Share on other sites
gadgetman 0 Report post Posted June 2, 2012 I'll be in for one of those too. Quote Share this post Link to post Share on other sites
HMM 0 Report post Posted March 13, 2013 Hi Kelly I am in a similar situation to you with E91 335i arriving ex Japan I am keen to sort idrive to work in English/NZ etc Plus Get phone/iPod connectivity Have seen some things on trademe-but-have reached a similar conclusion that you did Are you able o give me any clues from your experience with your 550!!?? Thanks Hamish [email protected] Quote Share this post Link to post Share on other sites
jake1829 119 Report post Posted April 13, 2013 Hi, I am also very interested to hear feedback as well , have a 335i arriving from Japan next month and would def be keen to get the i-drive system working here Quote Share this post Link to post Share on other sites
thexpat 0 Report post Posted June 20, 2016 Hi guys new on this forum just wondered if anyone knew how to reprogram radio to NZ stations got a e90 320i 05 model ccc idrive unit on some other forums they say press the M button for certain time and then its possible my DVD unit dosent have the MODE button any ideas how to do it Thanks Quote Share this post Link to post Share on other sites
Mongie 4 Report post Posted September 3, 2017 On 02/06/2012 at 5:07 PM, matt45 said: looking forward to a digital tv tuner being on that list. I've installed one but the reception is terrible. Not sure if its because the car is a jap import or not. It had digital tv already so just a straight swap! Quote Share this post Link to post Share on other sites
