allan 295 Report post Posted May 27, 2012 OK small quire on a 325 auto cooling system under the expansion tank, as per photo their is a thermostat is this something to do with the oil cooler or to do with the engine coolant. As on the manual system it is not present what if any thing it used instead of it. Photo shows both manual on the left auto on the right with thermostat Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 28, 2012 Its the automatic trans cooler thermostat, manuals dont have it Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 28, 2012 Can the auto bracket be used on a manual car? Quote Share this post Link to post Share on other sites
allan 295 Report post Posted May 28, 2012 Thanks Glenn had a feeling it was something like that. Tony not sure but if you could seal the holes up I don't see why not. Other may have different ideas wouldn't be to costly for something like that or should I have not said that BMW parts never can tell Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 28, 2012 Can the auto bracket be used on a manual car? Its best to use the correct adaptor plate. The radiators are the same Quote Share this post Link to post Share on other sites
