curryinahurry
E36 Front Lower Control Arms
Hi guys,
Just went for a warrant and unfortunately my E36 had failed for play in the front control arms.
Was wondering if I can just replace the bushes or would I need to replace the whole arm?
I'm thinking about doing the job myself (for interest sake), what brand other than OEM would be recommended?
Thanks a lot in advance!
Cheers,
Andrew
Edited by curryinahurry
OEM is the only way to go.
Unless you have done such work before I would recommend taking it to a dealer.
OEM and fitted for my car fitted from memory for both sides was around the three hundy mark. Not a BMW dealer though. Just the bushes.
