skidz 197 Report post Posted June 18, 2012 (edited) Hi guys, a friend here at work has a 2000 325i Motorsport; the heater fan has stopped working. Anyone know which fuse# and relay# to check? Or other likely cause? Cheers..Stephen Edited June 18, 2012 by skidz Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 18, 2012 It's most likely to be the final stage resistor... not the easiest to do Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted June 19, 2012 It's most likely to be the final stage resistor... not the easiest to do Thanks, Glenn. So, auto electrician, or just to BMW? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 19, 2012 Thanks, Glenn. So, auto electrician, or just to BMW? I'm not sure who to suggest ... maybe someone can suggest a reputable repairer down there Quote Share this post Link to post Share on other sites
Neal 554 Report post Posted June 19, 2012 Thanks, Glenn. So, auto electrician, or just to BMW? Either JGBMW or Page will be able to do that. Replaced one on an E36 , roughly an hour of discovering how trim comes apart. video here http://bmwresistor.blogspot.co.nz/ Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted June 19, 2012 (edited) I'm not sure who to suggest ... maybe someone can suggest a reputable repairer down there should have the part in stock and can fit for you 04 3801089 Edited June 19, 2012 by JKSE Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted June 20, 2012 should have the part in stock and can fit for you 04 3801089 Thanks, John I will let her know Quote Share this post Link to post Share on other sites
