HappyH00ker 30 Report post Posted June 27, 2012 Had clutch issue, yep was the Slave - found the outer seal was torn and leaking into bellhousing. Sourced new Master & Slave today, but the Slave doesn't have the pushrod included, I'm supposed to reuse the original.. only trouble is that the rubber tip is missing, may also be in bellhousing.. any suggestions where I can obtain either the pushrod or another rubber tip for mine ? Quote Share this post Link to post Share on other sites
Driftit 2251 Report post Posted June 27, 2012 Yeah you use the same rod. I spose you could get a new tip from BMW new. Wouldn't be much. Just give the rod a good polish and put a little lube on it. < Haha that sounds dodgey. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 27, 2012 (edited) Had clutch issue, yep was the Slave - found the outer seal was torn and leaking into bellhousing. Sourced new Master & Slave today, but the Slave doesn't have the pushrod included, I'm supposed to reuse the original.. only trouble is that the rubber tip is missing, may also be in bellhousing.. any suggestions where I can obtain either the pushrod or another rubber tip for mine ? The one I have here is 90mm with the nylon cap on it Give me a call John (09) 2722546 Edited June 27, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted June 27, 2012 Sterling clutch and brake can make one for you Quote Share this post Link to post Share on other sites
HappyH00ker 30 Report post Posted June 28, 2012 Yeah you use the same rod. I spose you could get a new tip from BMW new. Wouldn't be much. Just give the rod a good polish and put a little lube on it. < Haha that sounds dodgey. Ha, thanks Dan good advice, how long should I polish it Quote Share this post Link to post Share on other sites
HappyH00ker 30 Report post Posted June 28, 2012 (edited) Sterling clutch and brake can make one for youCheers Navin, Glenn from BotanyMotorWorx had one and some sound advice Edited June 28, 2012 by JohnE30 Quote Share this post Link to post Share on other sites
HappyH00ker 30 Report post Posted June 28, 2012 The one I have here is 90mm with the nylon cap on it Give me a call John (09) 2722546 Glenn you are a star, didn't get a chance tonite, but will have a look at the clutch fork on the weekend.. Quote Share this post Link to post Share on other sites
