jeffbebe 1587 Report post Posted July 3, 2012 Sprayed some carbon cleaner on the fuel rail and engine revs higher when cold, suggesting poor seals on the injectors. I've got a recon kit with new o rings, etc. There are some good DIYs online like this one - http://www.bimmerfest.com/forums/showthread.php?t=571302 Seems reasonably straightforward but wondering if I'm biting off more than I can chew as a reasonably practical but totally inexperienced hobbyist. Anyone done this or know if it's easy/difficult? Or what it might cost if I pay someone to do it! Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 3, 2012 Easy job to replace the fuel injector orings. Definately easy enough to do yourself The clips holding the injectors to the wiring are quite fiddly and easy to send flying into the engine bay. Be prepared for the fuel to come out and don't drop anything into the injector holes. Other then that I don't think you can really go wrong aslong as you make sure the injector seals sit properly. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted July 3, 2012 Easy job to replace the fuel injector orings. Definately easy enough to do yourself The clips holding the injectors to the wiring are quite fiddly and easy to send flying into the engine bay. Be prepared for the fuel to come out and don't drop anything into the injector holes. Other then that I don't think you can really go wrong aslong as you make sure the injector seals sit properly. Thanks, I might chance it then! Quote Share this post Link to post Share on other sites
