spanzyE30 0 Report post Posted July 15, 2012 hi, im new to this website! ive just bought some SSA 17x7.5 mags with +25 offset and wondering what thickness spacers i would need to make them fit my E30. we test fitted them and they hit the strut and on full lock hit the sway bar. look to mean to just get diff mags and got cheap enough to make them fit. need some good advice pleaseeee :confused: Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 15, 2012 the wont be a +25 offset and/or 7.5 wide if they are doing that, i gaurentee one of your measurements are wrong Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 15, 2012 the wont be a +25 offset and/or 7.5 wide if they are doing that, i gaurentee one of your measurements are wrong Yeah, the boxes they came in say +25 (and they are the right boxes) but they guy who sold them says they are 45 so maybe thatl help? Quote Share this post Link to post Share on other sites
euroriffic 624 Report post Posted July 15, 2012 Don't believe what the box says, I'd say 45 is right but to check look on the insides of the wheels and should have all the specs on them, size, width and offset Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 15, 2012 Don't believe what the box says, I'd say 45 is right but to check look on the insides of the wheels and should have all the specs on them, size, width and offset awesome, thanks, so with that offset what sort of spacers will i need this is my E30 btw Quote Share this post Link to post Share on other sites
euroriffic 624 Report post Posted July 15, 2012 (edited) I think I had 42 offset on my e30 and only just cleared struts. 20mm bolt ons are min thickness I would go but il let the e30 boys put their 2c in Edit: nice tidy e30 btw, I'd almost stick with the current wheels for an oem lookB Edited July 15, 2012 by euroriffic Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 15, 2012 (edited) awesome thanks for your help! yeah, i think they are mean on the car but its time for a change, i also like the look at the mo, this is the back though... Edited July 15, 2012 by E30_chik Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 15, 2012 looks like an AC Schnitzer kit which is nice! ideal E30 offset is between +25 and +10 so that would mean you need a 20-30mm spacer which is very thick Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted July 15, 2012 I've got the same wheels with +25 offset on my E30, as above, yours will probably be +42 should've bought mine! Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 15, 2012 (edited) Oh yeh that looks awesome. Did you need spacers? Yeh na it has ET 40 stamped on the back Edited July 15, 2012 by E30_chik Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted July 15, 2012 Nope, no spacers needed with +25 offset. Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 15, 2012 oh mean as, hope mine eventually fit lol Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 15, 2012 Et40 will fit E30 316i, 318i and some 320i models as they have thinner struts. I used to have et42 on my 320i and they were close to the strut but were fine. fyi for resale Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 20, 2012 So ive had a look at bolt on spacers on trade me and don't konw wether to go with 15mm spacers or 20mm spacers for the front. I don't want to buy them then put them on and find the rims still don't fit properly Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 20, 2012 if you insist using those wheels, get the 20mm ones. Quote Share this post Link to post Share on other sites
spanzyE30 0 Report post Posted July 20, 2012 cheers. would i need to worry bout the size of the center hole in the spacer? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 20, 2012 they have to be hubcentric BMW ones or you wont pass WOF/cert Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted July 21, 2012 i say atleast 20, preferably 25. i had a et40 rim on my car, didnt hit anything , stayed like that for a few years, just got spacers in it, had 20s, were quite big enough to make it look how i wanted so ive added extra slip on spacers aswell. the front is an et15 now and is pritty good the rears are gonna be et12. and with the hub centric rings, i had an issue with them not being avalible to fit the e30 hub, so got some other ones that were slightly smaller (toyota ones or somethng) and just sanded the inside out a little bit Quote Share this post Link to post Share on other sites
