Mark 178 Report post Posted August 31, 2012 Cheers to Andre3000 for the writeup here: Replacing E36 cabin microfilter - RHD cars. Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted September 23, 2013 Not sure how you can get back to the thread, but from memory, this is how I replaced mine: - Remove the panel under the steering wheel (one screw under headlight switch, another on the left around the indicator stalk, and at least one more underneath IIRC). - The microfilter is located behind the centre console (kinda behind the OBC). You'll see a round knob which you can turn and the cover will come right off. - Before you pull the old microfilter out, note how deep it sits inside the hole as it can be confusing how far in you need to push the new microfilter. This is also a good time to stick the vacuum cleaner in there and give it a good clean. - Install the new microfilter. You'll have to snap the new one where the plastic snap joints are to get it in, and it takes a bit of wiggling. You'll know you've got it in deep enough if the cover goes on and locks easily. Hope that helps. Btw, I find the best position to install it in is to be lying upside down in the driver's seat (with your head in the footwell). Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted September 23, 2013 Hope these help... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 23, 2013 Looks like any links you had before revert back to the old website and don't work any more. My old project links don't work now, so I'll have to dig them out and redo them Quote Share this post Link to post Share on other sites
paww 1 Report post Posted December 1, 2015 Anyone know a part number or where to find one of these filters? Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted December 1, 2015 (edited) realoem.com Chuck in chassis number, and have access to all the part numbers you could ever want. Will be available from Dealer, Milland or Euroitalian. Edited December 1, 2015 by KwS Quote Share this post Link to post Share on other sites
