Arma 134 Report post Posted September 1, 2012 (edited) Hey, Could anyone recommend a good panel beater at east Auckland? Botany/Howick/pakuranga/flat bush etc. area. Got a relatively ugly dent on my e39 that needs fixing (without messing up paintwork any further). Looks disgusting o_O, must get it fixed asap. Edited September 1, 2012 by Arma Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 1, 2012 To repair that the painting would be at least $400-$600 without the panel repair. You cant repair that properly and touch it up. BTW... I can recommend someone if you like but it can't be repaired properly for a couple of hundred dollars Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted September 1, 2012 To repair that the painting would be at least $400-$600 without the panel repair. You cant repair that properly and touch it up. BTW... I can recommend someone if you like but it can't be repaired properly for a couple of hundred dollars Ah How much do you reckon it will come down to for the person you want to recommend, including the panel repair + painting. The paint actually does not look very bad in real - the photo flash enhanced the scratch mark dramatically. From looking at it straight up it does not even look like the paint has come off. Couldn't a PDR be enough to fix the panel? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 1, 2012 Have a talk to Peter @ Prima Panel & Paint on Monday. They are in Harris Road Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted September 1, 2012 trouble is that you need to look at that as two dents, because the door and the quarter pabel are different body parts Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted September 1, 2012 Have a talk to Peter @ Prima Panel & Paint on Monday. They are in Harris Road Thanks I'll try to drop by at theirs sometime next week. trouble is that you need to look at that as two dents, because the door and the quarter pabel are different body parts I'm primarily focused on getting the quarter panel dent fixed first, since it's the worst one. If the door still looks horrible after that i'll probably get that done too. But yea, will have to pour in a bit more money since it's 2 panels I presume. Quote Share this post Link to post Share on other sites
