qube 3571 Report post Posted November 29, 2012 i got a quote for $900 to replace the two front shocks to monroe on a 1999 528i.. is this reasonable? its including all parts, labour and wheel alignment. Quote Share this post Link to post Share on other sites
explisick 0 Report post Posted November 29, 2012 (edited) i got a quote for $900 to replace the two front shocks to monroe on a 1999 528i.. is this reasonable? its including all parts, labour and wheel alignment. Nice....I would like to know how you get on if you can keep us informed, im looking at doing my front struts on my e39 touring .... theyre making a clunking noise and its so annoying while cruising! Will be getting quotes over the weekend.... FYI - i started a similair thred below this Edited November 29, 2012 by explisick Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted November 29, 2012 I think you will regret putting Munroes in, they're a horrible shock. I dont know who else stock Boge but id give SAS a call (09) 444 1390 as see what some boge shocks would cost you if you want an OEM ride. They gave a real good deal on Boge's for my E38 which ending up being cheaper than getting them overseas and way cheaper than some KYB's i was pricing up locally. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted November 29, 2012 i got a quote for $900 to replace the two front shocks to monroe on a 1999 528i.. is this reasonable? its including all parts, labour and wheel alignment. sounds like normal full retail. Why not go a b12 kit - i got a price of about 1400 +GST + install thats Eibach springs, Bilstein shocks and approx 40mm drop. from here: Simon Loveridge | SPEED NZ Limited 36 Newton street, Mount Maunganui, Tauranga, 3149, New Zealand Freecall 0508 2 SPEED (77333) Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted November 29, 2012 Price up OEM type shocks at Milland.co.nz. My m-tech ones were very reasonable, and they aren't difficult to fit. The Monroes are steel bodied (they were anyway) and the OEMs are aluminium - they are very light for such a big shock. Fitting only takes a couple of hours per side max (way faster in a workshop where 2 year olds haven't hidden half the tools). The same shop could fit the OEM type ones for you, probably. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted November 29, 2012 Nice....I would like to know how you get on if you can keep us informed, im looking at doing my front struts on my e39 touring .... theyre making a clunking noise and its so annoying while cruising! That noise may just be the sway bar drop links - VERY common on E39's, and very cheap/easy to fix. Quote Share this post Link to post Share on other sites
explisick 0 Report post Posted November 30, 2012 (edited) That noise may just be the sway bar drop links - VERY common on E39's, and very cheap/easy to fix. Thanks Allan, ill jack up the car and have a look around the end links and bushings once home Noise is driving me nuts!! Maybe Mr Milland would like to drop in on this conversation and provide some costs on OEM replacement and if possible some BOGE replacements? On that note why do people bag Monroes? Is it the ride or build quality or both? Edited November 30, 2012 by explisick Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted November 30, 2012 On that note why do people bag Monroes? Is it the ride or build quality or both? I haven't used them on an e39, but they were OK on my Suzuki Wagon R turbo. I'd just be concerned about the weight added. Lower unsprung weight helps with traction and feel. Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted November 30, 2012 Milland quotes $530 for a pair of Monroe reflex Sas quoted $480 each for boge Team mc millan quoted $525 each for boge Hmmm Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted December 18, 2012 Ended up getting them done at the first place I went. Cost $940 incl gst which was for Monroe reflex shocks front pair 4 hours labour Top hats for both shocks Had the arm bushings replaced Wheel alignment Car drives really good. It seems much more stiff than standard. Similar to my msport ones. Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted December 19, 2012 Indeed. E34 KYB valving is pretty firm like Bilstein HD rather than oem boges but they arent floaty and harsh like Monroes. Any new shock going to feel better than worn ones obviously but in my experience only replacing fronts or backs with a new condition shock and\or brand shows up the other end Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted December 20, 2012 Unfortunately what's been done is done. I have driven the car a bit more and I can see why these shocks are not so great. It's very harsh but regardless, given the condition the previous ones were in and the fact that there were not a lot of places available to do the job before Xmas, we went ahead with this one. Quote Share this post Link to post Share on other sites
