Filth 5 Report post Posted December 3, 2012 Hey guys, Randomly my back right window has decided not to go down any more :-( It did once upon a time but now when you press the button to have it down I hear a "click" sound and then nothing happens ... Anyone run into anything similar? And yes yes... I did make sure the window lock was set to unlocked lol Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 3, 2012 normally failed window motor and or window reg etc . easy enough to swap out for another have new and 2nd hand ones if needed. 021433600 Quote Share this post Link to post Share on other sites
jeffbebe 1584 Report post Posted December 3, 2012 Hey guys, Randomly my back right window has decided not to go down any more :-( It did once upon a time but now when you press the button to have it down I hear a "click" sound and then nothing happens ... Anyone run into anything similar? And yes yes... I did make sure the window lock was set to unlocked lol If you can hear something (i.e. the motor) then it's probably the window regulator. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted December 3, 2012 jeeze your having a bad run jordy Quote Share this post Link to post Share on other sites
Filth 5 Report post Posted December 4, 2012 jeeze your having a bad run jordy Hah Sadly :-( Quote Share this post Link to post Share on other sites
Filth 5 Report post Posted December 4, 2012 If you can hear something (i.e. the motor) then it's probably the window regulator. Any way to check? take the side panel door off and have a nosey? Quote Share this post Link to post Share on other sites
jeffbebe 1584 Report post Posted December 4, 2012 Any way to check? take the side panel door off and have a nosey? Best way to check is take it to someone like Brent who has spare motors and regulators, whip the door card off and try some working parts. I'd start with the regulator because it probably wouldn't make any noise at all if the motor was stuffed. But you'll which part needs replacing when the window works again! In the meantime, don't use the window! Quote Share this post Link to post Share on other sites
