Shemy
BMW e30 325i Air Conditioning
I've got a 1989 BMW E30 325I with an M20 engine in, the AC doesn't have a belt on at the minute. Does anyone know the size of the belt? I've got two sizes but I'm not sure which one...
12.5 x 810 - P/N 64521706826
or
12.5 x 823 KLIMA P/N 64551722990
Anyone got an idea on which one to get?
Regards
or
Regards
I used a 13 X 810
yea a 13 x 810 should be fine
Its a V belt so a larger section by .5mm wont bother it.
And there should be plenty of adjustment for either length to fit.
If you go into supercheap or repco the part number will likely be in the format 13A810 or 13A0810
but you could go anywhere from 790 up to 840 and it should fit.
Bit of trial and error if they dont have the right one on the shelf
Have you checked to make sure the compressor turns first..it may be seized
You probably just need a spanner to loosen the adjuster bolt, slip on the belt then tighten it up to adjust
^^^^ If the A/C belt runs behind the others - then yes
