Gaz 1077 Report post Posted May 11, 2022 (edited) Couple years have gone by, didn't realize it was 3! Not a huge amount has changed but kids will do that. Been through a couple different sets of wheels, style 5s, acs type 1 monoblocks. Picked up a dream set of ACS type 1 racing which I'll get widened to 17x9. Currently rocking some stye 24s however Ditched the msport kit and going more with an ASC theme. Picked up some type 1 mirrors, and painted them LSB as a tester as thinking about painting the whole car.. Had a slow coolant leak which was getting worse. Top hose looked average so replaced that..nope still leaking..so I guess nows a good time to upgrade the radiator. Was holding out for a s54 z3m one but all out of stock. Ended up grabbing a cheap used mishimoto one with new hoses. I had the radiator with the expansion tank built in so thought now would be a good time to upgrade to the m3 self bleeding system. Out with the old.. This was much harder than I thought. First, radiator didn't fit as the mounts are too narrow, grabbed some from a wrecker. Mine also has two wiring connectors up by the fuse box so tucked them underneath the expansion tank bracket for now. then I had run this hose which connected to old expansion tank, to the new one. I cut it in half and grabbed a joiner from the legends at A1. Sorted. Ran up everything and checked for leaks.. Pulled it out of the garage as to not gas out the Mrs in the office.. and it'd leaking fuel. At least it's good weather to daily the convertible Edited May 11, 2022 by Gaz 5 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 11, 2022 Poked my head under last night and this looks like the culprit. Loose hose clamp. Tried tightening it but made it worse.. then it got too cold and I gave up. Will give it a good clean and replace tonight and see how it goes. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 14, 2022 Much warmer in the garage today, managed to get the old clamp off and put a new one on.. fuel leaked sorted. Looks like it might still be leaking coolant, possibly from the thermostat housing (the one thing I over looked) I see there's a bunch of aluminum housing on the market. Anyone used one with success or just stick with a factory one. Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted May 15, 2022 My aluminium one has lasted well. However I've struggled with making gaskets for it, but that's more likely a me thing. Quote Share this post Link to post Share on other sites
