_Matt_ 42 Report post Posted January 29, 2013 After two years I've uncovered a few areas of rust that I want to fix so I can actually call my ride a minter. - boot (because of leaky light gaskets and boot seal) - left hood vent (not sure if a new hood and paint would be cheaper) - corner of drivers footwell (worst spot) And a little paint and panel work, scratches, cracks, a bent right fender after the snow Have others in chch had work done? Where would you recommend? I guess I just want a place that I can trust to do the job and keep it original and not just slap some sheet metal on for a quick fix. TIA Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 29, 2013 i wouldnt call "slapping on some sheet metal" a quick fix... slapping some bog in it would be a quick fix. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted January 29, 2013 i wouldnt call "slapping on some sheet metal" a quick fix... slapping some bog in it would be a quick fix. I mean lfabricating the sheet metal properly. This is an images from 2011 After its fixed I want it look original, with the circular cuts, the top lip, the pieces of metal to hold the wire etc... Quote Share this post Link to post Share on other sites
BM WORLD 1265 Report post Posted January 29, 2013 I mean lfabricating the sheet metal properly. This is an images from 2011 After its fixed I want it look original, with the circular cuts, the top lip, the pieces of metal to hold the wire etc... you possibly buy that part new and get it welded in etc check with bmw etc most small sheet metal parts are not to dare .i have a new bonnet in stock if needed. Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted January 29, 2013 give it a good clean inside afterwards just in case they missed some rust dust from cutting and grinding. good luck, f**king hate rust Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted January 29, 2013 you possibly buy that part new and get it welded in etc check with bmw etc most small sheet metal parts are not to dare . i have a new bonnet in stock if needed. Ill look into it and pm you... Back to panel beaters, any suggestions? Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 4, 2013 I have used RO Jones. They provide a broken down quote (parts, paint, hours, etc), have curtesy cars and they are professional. Quote Share this post Link to post Share on other sites
viettt 1 Report post Posted February 15, 2013 Ill look into it and pm you... Back to panel beaters, any suggestions? Action Auto Body Collision Care. Address: Cnr Hazeldean Rd & Selwyn St Propreitor: Brian Carson Phone: 03 379 4651 Email: actionauto@clear.net.nz They do amazing jobs. If you want to see the results on my just PM me. Quote Share this post Link to post Share on other sites
