beetee 0 Report post Posted August 15, 2005 QUESTION 1 ====just bought a 1989 320 i for the missus ( maybe i shouldnt have ) / on the dash is a light that stays on saying INSPECTOR // mechanic said do an oil change ?? DID THAT ?? next he said go to BMW and they will turn it off with a special tool / problem ?? to far to go to find a bmw man ????? anyone got a quick fix aside from removing the light from the dash :banghead: ============================= QUESTION 2 ===== under bonnet drivers side (( rh )) vacum type pot ? 2 hoses ( 10 mm ) one goes across fire wall other about 300 mm long goes nowhere ??? what is it for :banghead: :banghead: mate says its for breathing fuel tank ============================== statement if these problems are not fixable == CAR IS FOR SALE Quote Share this post Link to post Share on other sites
topless 13 Report post Posted August 15, 2005 on the dash is a light that stays on saying INSPECTORThat light is an aid to remind you to have the car checked according to the owner's manual, which includes an oil change. There are also a row of 5 green lights that go out one by one and when they get to the yellow light, that is the time to do an oil change. The service lights on the dash can be ignored, they don't do anything else except irritate you into doing something. There are methods to turn the lights off without the tool, remember seeing one posted here on Bimmersport fairly recently but can't find it at the mo'. With the older E30 with the small service plug, you could use a 12v 5w globe across pins 1 & 7 of the service plug to reset the lights but I don't know which pins to use on the facelift with the large plug.under bonnet drivers side (( rh )) vacum type pot ? 2 hoses ( 10 mm ) one goes across fire wall other about 300 mm long goes nowhere ??? My vent system for the tank is on the passenger side of 3 of my E30's, the 4th doesn't have one. So not sure what yours is on the driver's side.... Can you post a pic of the unit? Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted August 15, 2005 Here we go, this is how you reset the service lights. http://www.bmwe30.net/cgi-bin/datacgi/data...0042&Section=02 Cheers Grant Quote Share this post Link to post Share on other sites
ScD 0 Report post Posted August 15, 2005 I did my service light in my e34 last night. I just used a short length of wire. No problems Quote Share this post Link to post Share on other sites
beetee 0 Report post Posted August 16, 2005 THANKS FOR INFO ALL OF YOU // BETTER THAN A GARAGE // MISSUS GOT CAR AT WORK WILL TRY THE WIRE THING WHEN SHE GETS HOME // WHATS YOUR BREW :drunk: :drunk: :drunk: // WILL POST A COUPLE OF PICS LATER CHEERS Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 16, 2005 beetee - just make sure you short the correct wires for your model. I'm about to go and put some new plugs in my e30 as soon as I'm finished here - I'll have a look for the vacuum valve you mention. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 16, 2005 The only thing i can think of that might be it is the fuel pressure regulator - but if one of the hoses goes nowhere you got no fuel! and it should be on the front of the intake manifold. Otherwise take a pic cos I'm lost. Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted August 23, 2005 Although they suggest a fused jumper wire - I 've used a paper clip for the past 7 years without any problems... Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted August 23, 2005 I've used all sorts of things, but just be sure to connect the right wires, I got it wrong once on the oldskool styles and it started the car up...luckily it wasn't in gear at the time or it would've been disasterous Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 23, 2005 You also want a bit of resistance too, but up to you. Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted August 24, 2005 This works for me: if it doesn't for you - ignore it... Resetting E36 service indicator lights Tools: · 1 paper clip · ability to count to 11 (borrow a kid if this is too difficult) Procedure: 1 Car keys OFF 2 Remove plastic screw cover from diagnostic plug 3 Turn ignition key to position 2 (engine not running) 4 Using the paper clip, short pin 7 (ground) to pin 19 (reset) on plug & count 5 To reset oil service lights – count to 4 6 To reset inspection light – count to 11 7 Remove clip when time is up 8 Turn ignition off 9 Turn ignition on and check lights 10 If lights have not reset, repeat as required – vary your timing – it will work 11 Replace plastic cover on diagnostic plug All done! Why pay for a resetting tool?? Quote Share this post Link to post Share on other sites
