Nobimmer 694 Report post Posted February 27, 2013 I have some spare squirters if you need them too. Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted February 28, 2013 A heads up when looking to get the m50 block if you havnt already got it, there are ones with oil squirters that spray the underside of the pistons, some m50 blocks don't come with these, not sure what ones do and don't.Thanks for that bro, hard the m50 block im getting has them, hpf in the states installs them on there high hp e46 turbo m3's , any little adition helps Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted February 28, 2013 I have some spare squirters if you need them too.Cheers bra, the block im getting has them so im lucky haha Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted February 28, 2013 My brother wasnt home to help me lift the engine onto the stand so I lifted it myself and on the stand it sits haha time to pull that crank out now, hope my back isnt effed in the morning, just ordered m3 s50 throttle body from the u.k, it will be a task getting it to fit, Waiting on my black face gauges to turn up Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted February 28, 2013 not sure if it will work for you, but I have 3.0 M3 Camshafts that Im not using. If they work for your engine, make an offer. Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted February 28, 2013 Yeah I know what you mean but the block already has them, not necessary but every little bit helps Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted February 28, 2013 not sure if it will work for you, but I have 3.0 M3 Camshafts that Im not using. If they work for your engine, make an offer.Are they from a u.s.a spec m3? Or from a euro m3? Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted February 28, 2013 Are they from a u.s.a spec m3? Or from a euro m3? euro Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted February 28, 2013 euroYeah those cams wouldnt work with this head but thanks anyways bro Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted March 1, 2013 There are a few people that have made them fit (even in Nz). Move the tps sensor around and modify the oil filter housing and an adapter. I think i've seen some adapter plates being sold somewhere before. Are you going to track or drag this car? Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 3, 2013 There are a few people that have made them fit (even in Nz). Move the tps sensor around and modify the oil filter housing and an adapter. I think i've seen some adapter plates being sold somewhere before. Are you going to track or drag this car? Yeah your right you can make them fit with afew custom mods, some dude in nz had them on his 330ci looked nice, the car is just for the street and track days here an there will take it down the 1/4 mile see how it goes Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 4, 2013 This is the evo m3 rear sub frame, its getting sand blasted, then reinforced, then will get it powder coated so it should looks nice:) Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 4, 2013 The 6speed evo trans next to the 5speed ZF. Does anybody know what this sensor thing is on my evo clutch line??? What is the perpose of it? Do I need it or no? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 4, 2013 the six speed has pressed on gears you have to have them changed or youll kill it Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 4, 2013 the six speed has pressed on gears you have to have them changed or youll kill itThanks for that I will look into doing that, dont want to eff this box up thats for sure ! Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 4, 2013 good box but im using a better unit as such but harder to come by im sure itll work for you Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 4, 2013 New goodies , the biggest braker bar i could find haha 1m long 3/4" Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 4, 2013 good box but im using a better unit as such but harder to come by im sure itll work for youWhat sort of box will u run? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 4, 2013 265 dog leg Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 6, 2013 My 50mm Tail bov turned up today Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 6, 2013 265 dog legNice bro Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted March 6, 2013 (edited) This is the evo m3 rear sub frame, its getting sand blasted, then reinforced, then will get it powder coated so it should looks nice:) What are the differances between the m3 one and non? the part numbers are different but they look the same. Edited March 6, 2013 by Garett Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 6, 2013 What are the differances between the m3 one and non? the part numbers are different but they look the same. The Evo frame is a carrier for the large case diff. Big and strong, nice upgrade. Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 7, 2013 What are the differances between the m3 one and non? the part numbers are different but they look the same.The evo m3 rear end is alot stronger, I chose to use this along with the evo lsd diff, the axles are alot thicker too, perfect for high hp drift/drag setups, its just a bitch trying to source these Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 7, 2013 Got the crank out today, damn it ways abit ! Boxed it up now its time to order some custom l/c pistions , my wallet isnt looking to flash now haha Quote Share this post Link to post Share on other sites
