btccm3 1 Report post Posted March 6, 2013 (edited) as the title says im after a twin pick up and oil pump from an evo e36 m3 my 3L s50 powered car has much bigger tires now and is quite likely to pull some Gs through those long corners so don't really want oil surge Edited March 6, 2013 by btccm3 Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 6, 2013 as the title says im after a twin pick up and oil pump from an evo e36 m3 my 3L s50 powered car has much bigger tires now and is quite likely to pull some Gs through those long corners so don't really want oil surge Go s54 pickup... its a much better system for the problem with the pump which is actually to do with hard braking then high g corners afterwards. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted March 6, 2013 thanks man good to know Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted March 6, 2013 do you know if my 3.0 pump is good enough with a s54 twin pick up or will i need the s54 pump also? Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted March 6, 2013 (edited) Ive got a twinpickup S50B32 oilpump if your keen, no idea whats its worth. Also have the Sump. Edited March 6, 2013 by Jamez Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 6, 2013 for s54: The whole thing, Sump and all. The s50b32 path isnt a bad system, just not as good as the s54 solution. I'm personally running a 528 pump and pickup. But my sump is an m50 one which is at the front not the rear as with the m3. It has no issues as the oil doesnt drain the sump well under heavy braking like the s50 does. Here is an old post on the issue. http://www.bimmersport.co.nz/forums/index....showtopic=14550 edit: just buy Jamez one Quote Share this post Link to post Share on other sites
HELLBM 1698 Report post Posted March 7, 2013 Can do S54. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted March 8, 2013 what coin are we talking ray? pump+sump+pickup give me a call 0212233455 or txt "jared" Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted March 8, 2013 (edited) Ive got a twinpickup S50B32 oilpump if your keen, no idea whats its worth. Also have the Sump.is it form the revised model 3.2 what year car did the donor come from?I could be keen man how much you think you want for it? or quantra deal maybe do you need a car alarm or stereo installed perhaps? I can get all the major brands Edited March 8, 2013 by btccm3 Quote Share this post Link to post Share on other sites
