keen 6 Report post Posted March 31, 2013 Can someone help with the easy way to fit a new serpentine belt back on after replacing leaking oil gasket on filler plate. the car is a 2000 e46 318 Japanese import. There must be a simple way to back the tensioner pulley off but I'm dammed if I can see how it is. Quote Share this post Link to post Share on other sites
Eagle 1777 Report post Posted March 31, 2013 Should be tensioner lug bolt on middle pulley(17mm iirc) which you put a socket or spanner on and rotate anti clockwise to release tension Quote Share this post Link to post Share on other sites
keen 6 Report post Posted April 1, 2013 Should be tensioner lug bolt on middle pulley(17mm iirc) which you put a socket or spanner on and rotate anti clockwise to release tension I cant see a 17 mm anywhere near the pully. there is a 13mm on the pully but not keen to swing on that in case it comes undone. There are two holes that Im wondering if you somehow tension the pully right up, and slide a punch in there, and fit the belt and again somhow pull it out. Quote Share this post Link to post Share on other sites
Eagle 1777 Report post Posted April 1, 2013 Yeah it could be a 13mm and its on the pulley, i know what you mean but it doesn't come undone. You can slot a punch etc to hold tension but i managed to do it without needing to. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted April 1, 2013 Is this any help a n42 engine. Had to reduce it can you see the black and red arrows. From memory I put a socket on the nut, black arrow and removed the belt tension. Then with a nail or allen key slid it in the hole, red arrow when the two holes aligned. Quote Share this post Link to post Share on other sites
keen 6 Report post Posted April 1, 2013 Is this any help a n42 engine. Had to reduce it can you see the black and red arrows. From memory I put a socket on the nut, black arrow and removed the belt tension. Then with a nail or allen key slid it in the hole, red arrow when the two holes aligned. thank you both will give that a try Quote Share this post Link to post Share on other sites
keen 6 Report post Posted April 1, 2013 thank you both will give that a tryThanks very much guys you were quite correct. I put a socket and a power bar onto it and it worked like a dream. all back together and running great. Quote Share this post Link to post Share on other sites
