Ahmedsinc 414 Report post Posted April 12, 2013 Was anticipating the noise was being caused by obliterated clutch packs, which I had on back order from the states c/o the father in law. Thankfully we've been able to cancel the order and get a refund on the ordered parts. Was expecting to spend a few hundred by the time new bearings & seals were factored into the rebuild. Sending it back now would result in a net loss and will cost me time I don't currently have. Again, lessons learned. Now, to figure out what to do with a 3.64 gear set. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted April 12, 2013 You can buy LSD centers in NZ, a few come up on here and on trademe too for around $500 Quote Share this post Link to post Share on other sites
lukenewguy 0 Report post Posted April 14, 2013 Can you put a say 410 ratIowa Lsd centre into a 364ratio diff, if they are both the same case size? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted April 14, 2013 Can you put a say 410 ratIowa Lsd centre into a 364ratio diff, if they are both the same case size? The centers are the exact same, the only difference between diff's is the the ring gear and pinion gear. You would need to swap the 3.64 ratio ring gear onto the LSD before installing it into the 3.64 case (pinion gear will be different). Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted April 14, 2013 The centers are the exact same, the only difference between diff's is the the ring gear and pinion gear. You would need to swap the 3.64 ratio ring gear onto the LSD before installing it into the 3.64 case (pinion gear will be different). Setting up a diff requires someone who knows what they are doing. You can save yourself a lot of heartache by getting Kayne Barrie to do it properly so you actually get the real benefit of the LSD. To do otherwise is often penny wise pound foolish. Quote Share this post Link to post Share on other sites
jay^ 1 Report post Posted April 18, 2013 You can buy LSD centers in NZ, a few come up on here and on trademe too for around $500 Pretty sure i have one sitting in the garage that i need to get rid of if someone needs it. Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted April 18, 2013 Pretty sure i have one sitting in the garage that i need to get rid of if someone needs it.Will take it of your hands.Regards Ray Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 18, 2013 (edited) Dammit!! 11 minutes too slow Out of curiosity, how much do you sell them for, Ray? Edited April 18, 2013 by Ahmedsinc Quote Share this post Link to post Share on other sites
