Carl
Dashboard lights
Alright, so the left one is the parking brake, the middle one is the brake pads, but what is the right one?
Either brake fluid level or ABS.
If it is red - brake fluid level.
If it is orange then ABS.
Edited by bravomikewhiskey
Figures, I thought it had something to do with ABS, cheers
not Quite,
ABS is a red light that will only come on, If you have abs fitted to the car, goes off once the engine is started, if it stays on then there is a problem with the ABS system.
One of the lights (P) is park brake
One of the lights (!) is brake Fluid level warning, ( i think its this one)
the last one will be the the Front Brake pad warning
I Think that is the way they are. <_<
not Quite,
Yup, I an you are right, it is the brake hydraulics warning light.
Should come on and go straight out when engine has started.
If it comes on at any other time it is indicating that the brake fluid level is too low.
The ABS warning light actually has the letters ABS inside the circle.
Cheers
Grant
Edited by Grant
Not always - but the it might have nothing inside the circle. I didn't go out and check, but like I said ABS should be ORANGE and yes it does go off once engine is started.
Like I said Brake fluid or ABS.
Brake pad wear is the one with the dashed lines...
No - it is definately Brake Fluid, without a doubt. Definately not the ABS light.
I have double checked in the owners manual. Also I have the same light, with the same symbol and don't have ABS.
Edited by Grant
I have ABS in one of the e30's.
And that light is differant to the (!) one
Grant is right here, and I have also cross-checked the handbook. One of my E30's has ABS, the other 3 don't. The ABS light is the orange one next to the brake fluid warning light. The brake fluid warning light has nothing to do with ABS. Your ABS will still work even if your brake fluid is low and the warning light is on. (but not too low!!) The ABS light shows a failure in the ABS computer or ABS module.
