BreakMyWindow 1999 Report post Posted May 12, 2013 The menu rotary knob/button for my on board unit is stuffed. If i look at it funny the button will work sometimes. The scrolling part is fine however. Also, pretty much every other button except for the volume and power do not respond when pressing them. On the steering wheel all on board monitor related buttons dont work except for volume. This to me sounds like a pcb failure within the unit. Has anyone had this issue before? If so is it repairable, or time for a new unit? Thanks! Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 12, 2013 I'd say - just upgrade it to a 16:9 - you won't regret it! Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted May 12, 2013 Is it just a simple plug and play? Im not fussed with the nav not working but am concerned about the aspect ratio remaining 4:3 on a 16:9 unit. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted May 12, 2013 have good working 4;3 monitors if needed Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 13, 2013 Is it just a simple plug and play? Im not fussed with the nav not working but am concerned about the aspect ratio remaining 4:3 on a 16:9 unit. Plug & play BUT you need to replace both the monitor & the video module with 16:9 units. 3rd generation video module is both 4:3 & 16:9 compatible. Nav works with either. I changed them a few years ago - wouldn't go back Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted June 6, 2013 managed to get my 4;3 on board working again, and it was only to the tune of $60 The Rotary optical encoder (knob dial/button for scrolling menu options) was replaced. This was a generic part that i sourced from element14. Let me know if you want the part number. The internal spring mecahanism was stuffed, so scrolling worked, but you couldn't acknowledge anything with the push button. As for all the rest of the buttons on the onboard monitor, i simply removed the front cover, removed the circuit board, and cleaned the buttons, and contact points on the circuit board with CRC MAF cleaner (it's all I had) I guess it was either luck, or they were really dirty, but they all started working again upon re-installation. Steering wheel controls work now too! Quote Share this post Link to post Share on other sites
