e30ftw
E30 minor bits
Up to date as of 26/6/13 with the following;
m20 ICV - $50
m50 ICV - $50
M50B25 set of injectors - $80
51mm front left strut, $30
e36 M50B25 NV Engine loom (auto wiring cut) - $40
Set of e30 Boge shocks for 51mm struts ( I think they are Boge?? - Will be for sale in a couple weeks when I remove from my touring). Stock length, In good condition. Swapping for some Koni adjustables though.. $150
m50 AFM - $50 (Has small crack on plug and crack on a inlet)
Right rear Tailight, small crack - $20
+ Windows switches, Mint front indicators, side indicators.
Edited by e30ftw
  e30ftw said:
Bump - Listing all on TradeMe tonight.....
May be Keen on door cards, can you pm me your contact details
Cheers...Stephen
  e30ftw said:
Bump..
Let me know if the front wheel bearing sale falls through (how much did you want for it?)
Got the clock today by the way - cheers! Took me way too long to make that change.
$70, Will check in with them someone wanted me to hold on to it. Will let you know when they reply.
Allgood! What was in there? Been so long I can't even remember haha
No rush, just if the sale happens to fall through. Do you have two or just the one?
Just one of those non OBC digital one line display clocks
Just one, I bought a random set of 4 of TradeMe a store not wanting to stock e30 wheel bearings, so got 3 rears and a front quite cheap just wanted 2 of the rears.
BUMP
4.1 Diff added and price adjustments.. Feel free to offer!
None sorry will update this thread tomorrow with more random bits and remove whats gone. Diff . Under panel and bearings all gone.
