WANTED325iM 0 Report post Posted September 11, 2005 Check it out M3 motor Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted September 12, 2005 thatsa spicy meatball Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 12, 2005 raped S14 from japan . badass Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 12, 2005 I've been given the impression it's the 2.4 evo motor with the dogleg box Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted September 12, 2005 I've been given the impression it's the 2.4 evo motor with the dogleg box 2.4????? Quote Share this post Link to post Share on other sites
Dnz 0 Report post Posted September 12, 2005 Pretty cool, looks like its had a hard life tho! Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted September 12, 2005 Nice alloy corrosion on the throttle bodies. 2.4 Evo? Pass me that blunt Carl. I'd avoid like the plague. Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted September 12, 2005 Doglegs suck. They are weaker than the standard 5sp, and only good as a novelty. Id prefer to slap 2nd going down. Is this a 'plug n play' for e30s? (doubt it) Quote Share this post Link to post Share on other sites
BMW POWER 2 Report post Posted September 12, 2005 I smell a fish. He's stalling majorly. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 12, 2005 Sorry chaps, not 2.4, but the 220 hp evo 2.3 S14 engine Is that better? Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted September 12, 2005 Doglegs suck. They are weaker than the standard 5sp, and only good as a novelty. The M3 dogleg is different to E30 dogleg.Not plug and play at all. Nearly as much work as S50 swap required. Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted September 12, 2005 The M3 dogleg is different to E30 dogleg. Not plug and play at all. Nearly as much work as S50 swap required. How so? Id still way rather be pulling down for second.Who would want this then? Some m3 guy gonna pay $2.5k on that? Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted September 12, 2005 would be a good project if you had another $2000 to chuck into it... good turbo project... Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted September 12, 2005 hell yes...if you could rebuild that sh*t totally badass most e30 m3 aren't poor...the perfect engine for a wealthy gentleman to build into a 2.5 and rape the sh*t out of it Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 12, 2005 how on earth is the dogleg box weaker? M325: Its badass having 2nd and 3rd in the same gate. I'm sure it wouldn't be rocket science to put the motor in. Quote Share this post Link to post Share on other sites
