BMRBOI 8 Report post Posted September 20, 2013 (edited) Looking at buying one of them for the e36 325i. They seem to be popular in the net, anyone used them? Cost around $400-$445, i see some outfit does alloy radiators on tradme for $288Visit My Website Pay for what you get? Edited September 20, 2013 by BMRBOI Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted September 20, 2013 $245 from redline. http://www.redlineperformance.co.nz/produc...s/bmw/mgp-5430/ A workmate recently got one from redline to cut up and put in an rzr. Welds looked good inside and out. Not sure what other magic separates a good radiator from a sh*t one. Quote Share this post Link to post Share on other sites
Driftit 2198 Report post Posted September 20, 2013 There was a radiator stand at the Speed show that was really bagging on some of these cheap alloy ones. They had all sorts of comparisons putting them to shame. Never had one myself though so I can't speak from experience. I had a Koyo radiator in my old 180sx. Was great and really high quality. A few friends with high powered nissans run the Mishimoto rads and I have never heard a negative pep from them. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 20, 2013 Installed a redline alloy radiator in the 325i a while back (2yrs +) no trouble with it. Do have to say the inlet & outlet necks are shorter than factory but no issues with build quality to date Would like to know if they're chinese imports or locally built though Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted September 20, 2013 i think the biggest universal thing is you have to rubber mount it fully, it cannot ground out to the chassis. if it does it will get electric corrosion and eat away at the alloy and cause leaks. Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted September 20, 2013 Have a redline jobbie too and its ok. Only complaint is the lower drain valve is low quality brass which is chalky so replace before you install. Mine has broken the tip off. Hasn't effected the function overall. For the dollars in happy with it. Suspect china made. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 20, 2013 Have a redline jobbie too and its ok. Only complaint is the lower drain valve is low quality brass which is chalky so replace before you install. Mine has broken the tip off. Hasn't effected the function overall. For the dollars in happy with it. Suspect china made. How long ago did you get yours? Mine came with a plastic bung which so far seems ok. Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted September 20, 2013 End of 2010. The bung is a non issue for me as the rad is easy to drain and remove. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted September 20, 2013 Yep I also have one of the cheap ones in the race car and in my safari. Both had the same issue as Matt has described, the bungs were sh*t but replace with an old bolt and it works fine. No issues on either of them and they get a hammering, especially the one in the safari. Quote Share this post Link to post Share on other sites
