LsBeema 472 Report post Posted September 20, 2013 (edited) Hi beemer comrades. Because of the adjusties, camber gets abit high,so inner threads get eatin. swopped tyres over left to right first .having directional tyres is a must for high camber. Edited September 21, 2013 by e39525iM Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted September 20, 2013 Looks more like poor alignment or from hard cornering to me than camber wear. If it were camber wear the surface would have less tread on the inside than the outside of the tyre, not the very outer/side like you have shown. Quote Share this post Link to post Share on other sites
Dave@nz 11 Report post Posted September 20, 2013 (edited) Hi, Are you asking for recommendations on on wheel alignment if yes some basic information on the model would help also are the the ball joints, bushes etc in good order. May be the tow in is not enough otherwise for a tyre which is 80% worn out not abnormal. "Because of the adjusties, camber gets abit high,so inner threads get eatin" what does this mean? Edited September 20, 2013 by 87M3@NZ Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted September 20, 2013 Looks like toe issues to me. Have you had it aligned to confirm what the current settings are? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted September 21, 2013 Hi guys. I work at a Bridgestone tyre center. I notice slight drifting left to right when leaving the steering while driving,as a normal testing procedure,and the excessive tyre wear on fronts and l/rear .so I swopped front tyres left to right on the rims,and had to replace the l/rear tyre.here are the specs Front: cambers uneven.L high,non adjustable,so are the casters. too much toe out hence the inner tyre wear,and had a heavy steering,thought it could of been the pump.or me needing more gym Rear:left camber high with toe out,not good at all.there must be ample toe in with high camber to cancel out inner tyre wear. Standard inspection for any steering,bushing or bearings done. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted September 29, 2013 (edited) after adjustment. Edited September 29, 2013 by e39525iM Quote Share this post Link to post Share on other sites
