hybrid 1045 Report post Posted September 24, 2013 Official BMW M3 M4 Specs: 430hp, 369lb-ft, Under 3306 Pounds, Bi-Turbo Inline 6 CylinderMore here:http://f80.bimmerpost.com/forums/showthread.php?t=892746 Bi-turbo inline 6 cylinder 430 HP (approximately) / 369+ LB-FT (500 Nm) Higher than 7500 RPM redline Under 3,306 lb (1500kg) weight Fuel consumption & emissions reduced by 25% CFRP drive shaft, roof, trunk (M4), front strut brace, roof bow 6 speed manual standard, 7 speed DCT optional Active M Differential Forged Crankshaft Optional Adaptive M suspension Electric power steering 50:50 weight distribution Downloads SPECS ENGINE Inline 6 cylinder engine with two mono-scroll turbochargers Direct Injection VALVETRONIC Double-VANOS closed-decked crankcase twin-wire arc-spray coating (instead of liners) in cylinder bores reduce engine weight 430 HP (approximately) 369+ LB-FT (500 Nm) See Dyno Chart Higher than 7500 RPM redline TURBOS Two mono-scroll turbochargers Impulse charging for optimized responsiveness Flow-enhanced manifolds Electric wastegate actuator COOLING Double-flow oil recirculation pumps Turbocharger suction system Main radiator plus additional radiators for the high- and low-temperature circuits, turbocharger and transmission, Large indirect intercooler Low-weight magnesium oil sump Temperature-stabilizing electric water pump WEIGHT Under 3,306 lb (1500kg) weight (no mention if this is curb weight and no specifics provided as to what equipment included/not included in figure) compare to E46 M3 at ~3,400 lb curb weight compare to E92 M3 at ~3,600 lb curb weight compare to C63 AMG at ~3,900 lb curb weight compare to RS5 at ~4,000 lb curb weight ~ 7.68 lb/hp power to weight compare to E92 M3 at 8.7 compare to C63 AMG at 8.7 compare to RS5 at 9.0 compare to E46 M3 at 10.25 Fuel consumption and emissions reduction of 25% CARBON FIBER CONSTRUCTION CFRP drive shaft 40% weight savings over previous M3 increased stiffness reduced rotating mass for better acceleration and throttle response CFRP roof for both M3 and M4 saves 11 pounds (5kg) on M3 saves more than 13.2 pounds (6kg) on M4 CFRP roof bow Carbon fiber trunk for M4 (11 pounds (5kg) weight savings) CFRP front strut brace standard (weighs just 3.3 pounds (1.5 kg)) TRANSMISSION Standard 6 speed manual transmission automatic throttle blips on downshift more compact and quieter than predecessor E90/E92 M3 6 speed 26.4 pounds (12kg) lighter carbon fiber friction linings in synchroniser rings dry sump lubrication Optional 7 speed M DCT (double clutch transmission) with launch control Active M Differential (with constantly variable locking a la M5/M6) Forged crankshaft STEERING Electric power steering specially tuned for M3/M4 Servotronic function electronically adjusts the level of steering assistance Three modes: Comfort, Sport, Sport+ SUSPENSION / CHASSIS Optional Adaptive M suspension (with Comfort, Sport, Sport+ modes) CFRP front strut brace Double-joint spring strut front axle (saves 11 pounds) New five-link rear axle made from forged aluminum (saves 6.6 pounds) Aluminum suspension Aluminium stiffening plate Rear axle subframe fixed directly to body (bolted joints between the axle subframe and the body sills, without use of elastic rubber elements). WHEELS / BRAKES Lightweight forged wheels standard Staggered tire sizes M compound brakes standard (in blue) M carbon ceramic brakes optional (in gold) EXHAUSTExhaust features electrically controlled flaps just before rear silencer to minimize exhaust back-pressure as well as giving precise feedback on engine load. AERO 50:50 weight distribution Air Curtain M gills with integrated Air Breather behind front wheels MISC M3 and M4 to be introduced together (at Detroit NAIAS 2013 in January). M3 and M4 developed with help of BMW race car drivers Bruno Spengler and Timo Glock's participation in extensive testing and set- up runs on the Nürburgring-Nordschleife circuit, focusing on assessment of the cars’ suspension, tyres and all elements of the powertrain. Quote Share this post Link to post Share on other sites
gtstarped 73 Report post Posted September 25, 2013 "approximately" Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted September 26, 2013 very impressive. torque curve is amazing and the 7,500+ red line is good to see. Still going to miss the old N/A //M engines though 1 Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted September 26, 2013 Looks like an amazing car, lots of new technoligy to help it hold its crown as best in class, most impressive part for me is the weight reduction, its not confirmed but looks to be lighter than a lot of "hot hatches" on the market, that is remarkable for a car the size of a 90's 5 Series. Well done BMW, looks to be the best M3 yet! http://www.youtube.com/watch?v=mzfvHHjaEck Quote Share this post Link to post Share on other sites
liyi_92 37 Report post Posted September 28, 2013 very impressive. torque curve is amazing and the 7,500+ red line is good to see. Still going to miss the old N/A //M engines though I second this... Quote Share this post Link to post Share on other sites
michhod 26 Report post Posted October 10, 2013 Being as these look like british specs, a 6 speed manual will be standard...I wonder what NZ will get as standard, flappy paddles?! Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted October 10, 2013 Good point, seems BMW NZ thinks we all want automatic. When I went to test drive the M135i I asked for a manual car and I was told that all local stock are automatic and manual is "special order" he then went on to tell me I didn't want a manual and brushed the idea aside as if was no big deal. I hear that BMW are doing a special M4 next year to coincide with 100 years of BMW, that may be the one to look out for. Quote Share this post Link to post Share on other sites
