alaza 1 Report post Posted November 5, 2013 So recently brought a car, and found out it had these cheap nasty china made locking nuts, so i used the locking nut key, after doing two bolts, the key thread is stripped. was wondering if anyone got a key for it? just trying my luck Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted November 5, 2013 Hi - you got this sorted yet?? Quote Share this post Link to post Share on other sites
alaza 1 Report post Posted November 6, 2013 ALL sorted by using a 20mm socket bashed into the bolts and took it out Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted November 6, 2013 Ahh good, was gonna give ya some suggestions otherwise. Nice that a bit of brute force & 'pass me a bigger hammer' has worked - you might want to chuck those cheapies over your shoulder now & get some decent ones....... Quote Share this post Link to post Share on other sites
740i_Lou 5 Report post Posted December 10, 2013 Just a quick thread hijack. I have a similar problem. I bought a 7 series on the weekend and have gone to take a wheel off to sort a squeeky brake to find that it has lock nuts but I have no key. I dont really want to brake my socket set or make the nut harder to remove. Is doing that way the best/easiest method? Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 10, 2013 If you have AA or similar cover, it's worth giving them a call. If not, it is possible to buy 'keys' for locking nuts, but it'll probably be cheaper to buy another suitably-sized socket. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted December 10, 2013 Assuming they BMW locknuts and you want to keep them a new key should be around mid $20 at a dealer. Quote Share this post Link to post Share on other sites
740i_Lou 5 Report post Posted December 10, 2013 I'm not too fussed on keeping them. I just want to sort the squeel out as its driving me nuts. I do have roadside assistance with state. Is it worth ringing them? Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted December 10, 2013 The last key i got from team mcmillan was around $16 from memory. Just take the car into the parts guys & they will have a full set to try one at a time. Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted December 10, 2013 Just a quick thread hijack. I have a similar problem. I bought a 7 series on the weekend and have gone to take a wheel off to sort a squeeky brake to find that it has lock nuts but I have no key. I dont really want to brake my socket set or make the nut harder to remove. Is doing that way the best/easiest method? Chuck up a pic of the offending item maybe?? Theres various ways to remove them if the correct nut is not available - you've just got to find the easiest solution, which will depend on what type of rims / what type of lock nut it is, & how much clearance you've got....... Have you rang previous owner re lock key?? Have you had a REALLY good look, three times, all around the car for the lock key, in both logical & illogical places........??? Like, the toolkit, spare wheel well, glove box, consoul, under seats, etc etc........stashed in first aid kit if its got one, is another likely place....... Quote Share this post Link to post Share on other sites
740i_Lou 5 Report post Posted December 10, 2013 Yeah stripped the car looking. I might take it into BMW tomorrow. They are only up the road. Hopefully they can sort it. Quote Share this post Link to post Share on other sites
740i_Lou 5 Report post Posted December 11, 2013 Called into Coombes BMW on the way home. Figured it out in a couple of seconds and had the right one on hand. Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted December 11, 2013 Primo - great result, & simple............ Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted December 11, 2013 If I'm not mistaken, there are a hundred and something "bmw" lock nuts and keys. Last time I went into team mc millan they told me it's gonna be ages to find the right one. And I was a bit rushed so I left it for another day. Then I tried my lock key from another bmw I had at the time and it worked.. Now what are the chances of having two cars both with the same locknut/key?! Haha.. Quote Share this post Link to post Share on other sites
740i_Lou 5 Report post Posted December 12, 2013 I think you may be mistaken. When I told the service guy I needed one I only said it was a 7 series. He bought out a tray with maybe 30 keys. Pulled out the one labeled E38 and it fitted perfectly. He double checked it wasn't one that looked similar but that was too loose. Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted December 12, 2013 So technically, its not really that hard for the Midnight spares boyz to be grabbing a set of rims off a 7 series then ae Heres a wee hint - if you like the rims your car has got on it, probably be a great idea to get some good quality aftermarket lock nuts for it - not BMW ones........ 1 Quote Share this post Link to post Share on other sites
