gtstarped 73 Report post Posted January 14, 2014 Garage is littered with this stuff at the moment so needs to go Large case 3.07 LSD - $1 reserve (guts can be used in other diffs like E34's) http://www.trademe.co.nz/Browse/Listing.aspx?id=685256279 E28/E24 large case LSD $450 offers http://www.trademe.co.nz/Browse/Listing.aspx?id=683764598 E36 3.64 LSD from my track car $850 http://www.trademe.co.nz/Browse/Listing.aspx?id=683175562 E36 M3 3.15 LSD - Guts can be used in other medium case diffs - $680 offers http://www.trademe.co.nz/Browse/Listing.aspx?id=685256271 M30 Longblock - Good runner but probably needs rear main seal - $1 reserve I have all other components to make complete. Higher compression M30 http://www.trademe.co.nz/Browse/Listing.aspx?id=685523873 E36 M3 wheels (copies, non staggered) - $350 offers http://www.trademe.co.nz/Browse/Listing.aspx?id=683764774 E36 325i/328i Bilsteins - $500 http://www.trademe.co.nz/Browse/Listing.aspx?id=683764772 E36 front leather coupe seats - $1 reserve http://www.trademe.co.nz/Browse/Listing.aspx?id=683176444 Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted January 14, 2014 Excuse my ignorance but could guts of the large case diff fit an E39 diff? Quote Share this post Link to post Share on other sites
gtstarped 73 Report post Posted January 14, 2014 Yep I believe so. As urs is large case and so it is, it will have the correct type lsd size. Best give Kayne Barry a call on 0274975330 if you needvit done. Thanks Quote Share this post Link to post Share on other sites
Gaz 1067 Report post Posted January 14, 2014 What mods are needed to the 3.15 diff to fit a 328? Quote Share this post Link to post Share on other sites
gtstarped 73 Report post Posted January 14, 2014 What mods are needed to the 3.15 diff to fit a 328? The LSD portion of the 3.15 Diff is taken out and put in yours, or the front section of the 3.15 is altered to match yours to bolt this straight in. It needs to be torqued correctly but is a fantastic upgrade for enjoying your power while sliding! Quote Share this post Link to post Share on other sites
euroriffic 625 Report post Posted January 15, 2014 Not true, there a different thickness to where the crown wheel bolts up to so doesn't line up properly, there's two different thicknesses, one for 2.92 and below which is a manual 328i ratio and for above. Got caught out Afew years back Quote Share this post Link to post Share on other sites
gtstarped 73 Report post Posted January 15, 2014 Not true, there a different thickness to where the crown wheel bolts up to so doesn't line up properly, there's two different thicknesses, one for 2.92 and below which is a manual 328i ratio and for above. Got caught out Afew years back Yeah damn you're right, forgot about this. However there is a way around this if the diff is being rebuilt. Ive used M3 centre LSD's before on 2 3.64 diffs so can be done but costs a bit more. Effectively if you're willing to pay for a rebuilt diff, you can have the LSD in any medium case diff no matter the bolt hole size. Quote Share this post Link to post Share on other sites
