gtstarped
Need to move LSD's, M30 engine, E36 Billsteins, leathers and M3 co
Garage is littered with this stuff at the moment so needs to go
Large case 3.07 LSD - $1 reserve (guts can be used in other diffs like E34's)
http://www.trademe.co.nz/Browse/Listing.aspx?id=685256279
E28/E24 large case LSD $450 offers
http://www.trademe.co.nz/Browse/Listing.aspx?id=683764598
E36 3.64 LSD from my track car $850
http://www.trademe.co.nz/Browse/Listing.aspx?id=683175562
E36 M3 3.15 LSD - Guts can be used in other medium case diffs - $680 offers
http://www.trademe.co.nz/Browse/Listing.aspx?id=685256271
M30 Longblock - Good runner but probably needs rear main seal - $1 reserve
I have all other components to make complete.
Higher compression M30
http://www.trademe.co.nz/Browse/Listing.aspx?id=685523873
E36 M3 wheels (copies, non staggered) - $350 offers
http://www.trademe.co.nz/Browse/Listing.aspx?id=683764774
E36 325i/328i Bilsteins - $500
http://www.trademe.co.nz/Browse/Listing.aspx?id=683764772
E36 front leather coupe seats - $1 reserve
http://www.trademe.co.nz/Browse/Listing.aspx?id=683176444
Excuse my ignorance but could guts of the large case diff fit an E39 diff?
Yep I believe so. As urs is large case and so it is, it will have the correct type lsd size. Best give Kayne Barry a call on 0274975330 if you needvit done. Thanks
What mods are needed to the 3.15 diff to fit a 328?
The LSD portion of the 3.15 Diff is taken out and put in yours, or the front section of the 3.15 is altered to match yours to bolt this straight in. It needs to be torqued correctly but is a fantastic upgrade for enjoying your power while sliding!
Not true, there a different thickness to where the crown wheel bolts up to so doesn't line up properly, there's two different thicknesses, one for 2.92 and below which is a manual 328i ratio and for above. Got caught out Afew years back
Yeah damn you're right, forgot about this. However there is a way around this if the diff is being rebuilt. Ive used M3 centre LSD's before on 2 3.64 diffs so can be done but costs a bit more. Effectively if you're willing to pay for a rebuilt diff, you can have the LSD in any medium case diff no matter the bolt hole size.
