martyyyn 102 Report post Posted January 30, 2014 I thought I would try one on the car this evening to see what they would look like (not that I don't know having had several sets over the years) but they are hard up against the rear trailing arm so I went to take it off but it's stuck fast. I've had this before on an e39 and a gentle tap with the spare swung between my legs did the trick but this isn't budging. I've drowned it in WD40, tapped it, wiggled it even kicked it, but nothing. Any suggestions ? As for the width, I always thought B10's used 10" rears and I researched plenty of sites which said they would fit the e34 with no problem, so why are they hard up against the trailing arm ? My concern was the 265 tyres not fitting under the arches as I have Bilstein and Eibach suspension but that seems a long way off at the moment. It doesn't have a tyre on either so it's not as if I can drive it to someone with a bigger hammer. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 30, 2014 whats the offset of the rims? probably too low?? there is PLENTY of room in the rear wheel well for almost anything you like in an E34, im running 255s on Schnitzers, and plenty of room still both inwards and outwards Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 30, 2014 whats the offset of them, we had the 10" on the back of our e34 , i think the offset was about ET3 or 5 etc had enough clearance with a 255/40-17" just you sure they are 5 /7 series offset not 3 series ones?? Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 (edited) They are e28 which I would've thought was fine. Now I'm finding mixed reports with some people saying they are a straight bolt on to the saloon, with others saying it was an issue on tourings. Dont know if I want to grind the lip off like some have done, or run spacers. They are wide enough as it is. Edited January 30, 2014 by martyyyn Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 30, 2014 They are e28 which I would've thought was fine. Now I'm finding mixed exports about some people saying they are a straight bolt on to the saloon, with others saying it was an issue on tourings. Dont know if I want to grind the lip off like some have done, or run spacers. They are wide enough as it is. didn't know that they had a model of wheel in 10" for a e28?? got pics etc , what is the offset?? Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 They are 10J*17H2 e28 and the part number is 3611639 which I believe are B10 rears. Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 (edited) The offset is 28 Brent, not that they are for an e28 I'm just sorting some photos now. Edited January 30, 2014 by martyyyn Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 30, 2014 (edited) ok that is a 3 series offset , so fronts are about a ET35 8.5" wide ? so you would need approx 20mm bolt on spacers etc Edited January 30, 2014 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 The fronts are 8.5Jx17H2 +12 part number 3611638 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 30, 2014 The fronts are 8.5Jx17H2 +12 part number 3611638 that should be fine, my schnitzers are 17"x8.5 et13, so only 1mm diffference in offset. but the 17"x10" et28 should be surprised if it will work, probably need to be in the et0-10 range i should think. and there is no difference between touring and sedan, all the suspension is the same between both, body contours the same in the wheel well area etc etc... Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 30, 2014 (edited) The fronts are 8.5Jx17H2 +12 part number 3611638 ok fronts sound like the correct ones for a 5 series but rears are wrong ,even for a e28 as the e28 and e34 rear trailing arms are the same part number maybe they used some spacers maybe around 10mm etc to get enough clearnace for tyres to fit in the back of the e28 , as the e28 dont have as much space in that area compared to a e34 and i doudt you could get a proper low offset 10" wide in the back of a e28 with decent width tyres without modifing the gaurds Edited January 30, 2014 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 30, 2014 i actually cant even think of any car that would run that combo 17x8.5 et12 17x10 et28 sounds like a missmatched set of wheels???? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 30, 2014 i actually cant even think of any car that would run that combo 17x8.5 et12 17x10 et28 sounds like a missmatched set of wheels???? i agree Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 (edited) I found a post from Boris (Mr_e34) on forum5.co.uk saying they are an e32 fitment and will only fit an e34 with modifications to the rear trailing arm. Bugger. I had the exact same combination on an e32 750iL in the UK too. Edited January 30, 2014 by martyyyn Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 So back to the original problem....how the hell do I get it off ? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 30, 2014 block of wood and a hammer , maybe let some air out too Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 30, 2014 how did you not notice when you torqued it right up??? you will need to get behind the wheel 180degrees from where it is hitting the trailing arm, (so invisible line from where it is hitting the trailing arm, through the hub, to the other edge of the wheel) and use the trailing arm as the pivot point rather than the hub. probably the only way it will come off. failing that, a bit whorey, but you could try putting the car in drive, and letting the wheel spin and pop it self off. unlikely to break anything, but not exactly the mechanics method... Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted January 30, 2014 I didn't torque it right up, but there was bugger all resistance when I did it. Nothing more than I've experienced in changing hundreds of wheels previously. Quote Share this post Link to post Share on other sites
e38king 1 Report post Posted January 31, 2014 ok fronts sound like the correct ones for a 5 series but rears are wrong ,even for a e28 as the e28 and e34 rear trailing arms are the same part number maybe they used some spacers maybe around 10mm etc to get enough clearnace for tyres to fit in the back of the e28 , as the e28 dont have as much space in that area compared to a e34 and i doudt you could get a proper low offset 10" wide in the back of a e28 with decent width tyres without modifing the gaurds i actually cant even think of any car that would run that combo 17x8.5 et12 17x10 et28 sounds like a missmatched set of wheels???? i agree a bit late but they are not mismatched rims, they are from a 7 series. All 7 series run a slightly higher rear offset. They best way to get the wheel off is to hit it with a rubber mallet. Can you spin the rim around at all by putting the car in neutral. If so this will let you bang it at different points around the rim. I would also be putting down an old blanket under the rim as Murphy's law says it will pop off at the wrong moment and land on the face putting bug scratches on it. Quote Share this post Link to post Share on other sites
