nz320i 0 Report post Posted October 11, 2005 (edited) my car is quite low, but is legal, the warrant guy doesnt mind but he wont pass me for one thing: on one side (rear left) the tyre rubs when driving over bumps on the INSIDE of the gaurd???? how can i stop this, he said it cannot touch when on a bump or has to be out so much, would a new shock fix this? Edited October 11, 2005 by nz320i Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 11, 2005 i was told it could possibly be a bent rear arm?? Quote Share this post Link to post Share on other sites
318is 0 Report post Posted October 11, 2005 I guess if you got pump up air shocks you could do that, then lower it by releasing X amount of air out of them. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted October 11, 2005 Correct your negative camber, this will stop the wheel rubbing on the inside. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 11, 2005 how do i do that? i didnt know it was adjustable? Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted October 11, 2005 nz320i said: how do i do that? i didnt know it was adjustable? It isnt adjustable, you need a camber kit - some people were doing a group buy on them a while ago...Is the rubbing on the gaurds or chassis rail or suspension? A gentle persuader will fix gaurd problems as you can stretch them out, but I would suggest finding out why it only does it on one side also. Quote Share this post Link to post Share on other sites
DCEIVN 0 Report post Posted October 11, 2005 Negative camber could also possibly be due to a poked rear strut couldnt it? I'm not an expert but I remember I had a similar problem when I 'aired' my dads peugeot at an inappropriate place. Do you have any wheel alignment issues like does the car pull one way or another? Quote Share this post Link to post Share on other sites
DCEIVN 0 Report post Posted October 11, 2005 Quick fix: get a thinner wheel and tyre set on temporarily???? Quote Share this post Link to post Share on other sites
topless 14 Report post Posted October 11, 2005 Quote It isnt adjustable, you need a camber kit You don't necessarily need a camber kit... it can be done reasonably easily and cheaply, have done quite a few this way. Posted a bit of info on it a while back. Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted October 11, 2005 topless said: You don't necessarily need a camber kit... it can be done reasonably easily and cheaply, have done quite a few this way. Posted a bit of info on it a while back. Yep sure you can do it yourself, but still requires mods that should still be certified by an engineer (me) unless you are relying on the 'nobody will see it' clause in the law Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted October 11, 2005 Quote on one side (rear left) the tyre rubs when driving over bumps on the INSIDE of the gaurd for good reason too.when the tyre rubs on the inside its almost impossible to keep track of how they are wearing,so it could be almost worn through when you go on your big road trip.......ever had a blowout or rapid tyre deflation at speed? Quote Share this post Link to post Share on other sites
petone 0 Report post Posted October 11, 2005 Is it hitting the actual metal on the guard? Would a quick whack with a hammer fix it? I doubt shock would help at all, they only do dampening. Its the 2 mounts on the trailing arm that control the movement. Bent rear arm is possible, what are your wheel alignment specs like? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 11, 2005 Mate, could just be your wheel offset is too big Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted October 11, 2005 As you said that its only one side that is doing it. My guess would be that something is bent. As mike said, whats your alignment like. This would prob tell you that something is out. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted October 11, 2005 Damo said: topless said: You don't necessarily need a camber kit... it can be done reasonably easily and cheaply, have done quite a few this way. Posted a bit of info on it a while back.Yep sure you can do it yourself, but still requires mods that should still be certified by an engineer (me) unless you are relying on the 'nobody will see it' clause in the law are you a LVVC certifier? Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted October 11, 2005 I've got some 14" Basketweaves that _might_ fit your car you could borrow That or some 215 5 spoke 17's in FWD offset Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 12, 2005 Surge said: I've got some 14" Basketweaves that _might_ fit your car you could borrow That or some 215 5 spoke 17's in FWD offset haha ohh my old wheels na i think i might be right, talked to pete at euro wreck man hes help full! getting a wheel alignment tomorrow to see if it is really stuffed then i will know what im doing, Anyway regardless of that the MANUAL conversion!!!!!! is going ahead next friday taking to eurorec and well have a look at everything then yay manual cheers guys for the help Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 12, 2005 petone said: Is it hitting the actual metal on the guard? Would a quick whack with a hammer fix it? I doubt shock would help at all, they only do dampening. Its the 2 mounts on the trailing arm that control the movement. Bent rear arm is possible, what are your wheel alignment specs like? hehe i thought of the hammer trick..would the warrant place be sweet?!!getting an alignment done tomorrow arvo so ill post what happens Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 14, 2005 Awesome, The guy at firestone smaked my inner guard out and was like it should be sweet mate. haha what a good guy. Passed the warrant with a bit of explaining.. And now the pedal box is in!! Quote Share this post Link to post Share on other sites
