Neal 575 Report post Posted February 3, 2014 (edited) Seems each time I talk with a E46 M3 SMG owner I'm finding that we all seem to like different settings for the SMG shift patterns and speeds. Looks like there are a number of owners & ex owners on here. M3 Power has suggested some settings previously for excellent technical reasons , (3 manual , 3 auto) So, what's your settings and why ? here's mine Manual mode 4 , DSC on ( car is in this mode the majority of the time) Seems similar to a quick manual gear change Auto Mode 2, DSC on Only used in stop / start motorway , seems to change up at 2,200 rpm with light throttle with smoothish changes track days / driver training Manual mode 6 , DSC off , sport throttle setting, but avoid full throttle changes 1-2 Edited February 3, 2014 by Neal Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 3, 2014 All I know is I prefer to lift a little on gear changes .. goes in way better on most SMG m3s ive driven. 6 is a bit to pointless and brutal for my tastes with no real gain in performance. Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted February 4, 2014 (edited) I run mine on s3 basically all of the time now and nothing more than s4. s6 is just far too brutal, even s5 is a bit too much sometimes in my opinion. You should NEVER lift in an SMG car, once calibrated correctly you shouldn't need to. And if you do, it'll just slip the clutch overtime as it adapts. According to the US guys who have been dissecting the coding for the SMG tune for both standard m3 and CSL the difference is vast. The S5 shift speed is about the equivalent of the S3 shift speed in the CSL. The torque ramp up is also 100% (in the CSL) vs 60% (in the standard M3) - this is what gives it that instantaneous perfect rev match in the CSL. There are apparently 6 different maps for the DME for the upshifts and 6 more for the downshifts characteristics - each of those incorporating a full throttle map (100% torque load) It is now possible to fully flash the CSL SMG software together with the corrected CSL DME codes to match (you need to do both, otherwise it is pointless as it'll just give you the higher launch modes and slightly better upshift speed, but you lose out on the downshift torque match from the DME). Edited February 4, 2014 by M3_Power 1 Quote Share this post Link to post Share on other sites
mrphil 1 Report post Posted February 5, 2014 I used to drive mine in s3, never lifted when changing gears and never used the auto mode S6 is nuts, seriously track only mode Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted March 18, 2014 (edited) I'm actually finding S2 is my preferred. It's smoother. Is there a reason I should be using s3 instead? Edit. I'm back on s3 and agree it's prob the best all round. Edited March 29, 2014 by Nick G Quote Share this post Link to post Share on other sites
