paulo 86 Report post Posted February 4, 2014 Hi there, I'm after the following parts for my e38 740i 1999/2000 (M62 Vanos engine) 1) Water cooled alternator. One from a 1999+ 540i or X5 would also do. Needs to be a guaranteed good working item 2) Steering column ignition switch, oem part number is 61326901962 from a 1997 onwards 740i , 750i, 540i or X5. CheersPaul Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted February 4, 2014 I wouldn't bother with a used ignition switch - they're pretty crappy, and new is about $180 I think. Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted February 14, 2014 Those alternators are scary expensive, are you sure you need a new one? I was told i needed a new one but it turned out the battery was knackered, much, much cheaper fix!! Quote Share this post Link to post Share on other sites
