allan 295 Report post Posted February 20, 2014 (edited) Wish to swap out the heater controls from the dial type, top part of photo to the push button pixel display bottom part as per photo. Is this a straight swap or does some aligning, coding of the new unit need to be carried out thanks for your assistance. http://i1146.photobucket.com/albums/o526/Allanson54/heatercontrols_zpsf9a5a3e4.jpg Edited February 20, 2014 by tim 325 Quote Share this post Link to post Share on other sites
Neal 568 Report post Posted February 20, 2014 (edited) Will need one if those dam hedgehog resistor thingies . Need the dexterity of a cat to fit one. I've had three e36s . One had manual aircon which was fine at 225k . The other two had dual climate and either the hedgehog resistor failure or the diode issue within the first 150k of running. The manual system is basic, but IMO is more reliable on the e36 and the dual zone isn't worth it . Edited February 20, 2014 by Neal Quote Share this post Link to post Share on other sites
allan 295 Report post Posted February 20, 2014 It is for an e46 guys. Quote Share this post Link to post Share on other sites
Neal 568 Report post Posted February 22, 2014 Could you make any sense out of the WDS on this one ? My guess is that you'll also need to add the hedgehog looking resistor into the aircon airbox. It controls the fan speed based on temperature settings on the auto panel. Also of note is the resistor is unreliable in its first form so look for the revised part numbers. BMW Heater Fan speed resistor 64116923204 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted February 23, 2014 Thanks for the info guys this idea is being shelved for now other things taking priority. Quote Share this post Link to post Share on other sites
