Arron 227 Report post Posted March 9, 2014 Hi all Just looking at buying a s50b32 with no dme so we are going to be looking for a dme,ews and key Does anyone have a set that they want part with?? Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted March 11, 2014 Somebody must have one somewhere Quote Share this post Link to post Share on other sites
Tidy30 38 Report post Posted March 11, 2014 Will keep a lookout for you Mr. N! Sent from my Nexus 5 using Tapatalk Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted March 11, 2014 Im pretty ews module and key dont have to be from the same ecu or even the same car as im pretty sure that you can sync/bind ews key and module to the ecu via a scanner of some sort. my cheap scanner has this option. I could be wrong tho, but a m3 specific ecu if needed, sadly people dont often want to part them from thier engines The other option could be getting the ecu flashed to remove ews from system entirely. Maybe give darren @ NZAD a call he might be able to import one for you. Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted March 11, 2014 Hi there Cheers for the replies. I have already spoken to Darren and he is looking Into it for me. I can get a set from the uk for about £250 but want to try here first. As for the ews ideally we want t complete set so we don't have to worry about fiddling round with programming it to other ews chips ect. If I have to I will send one (when I find one) over seas to have the ews removed Cheers Quote Share this post Link to post Share on other sites
euroriffic 625 Report post Posted March 12, 2014 Just run an aftermarket ecu with air flow delete and trumpets off the itb's Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted March 12, 2014 yeah we cant do that. for what we are putting it into we need to use factory parts Quote Share this post Link to post Share on other sites
euroriffic 625 Report post Posted March 12, 2014 Ahh fair enough then. Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted March 14, 2014 well it looks like ebay might be our only option Quote Share this post Link to post Share on other sites
