Arron
S50b32 dme,ews and key
Hi all
Just looking at buying a s50b32 with no dme so we are going to be looking for a dme,ews and key
Does anyone have a set that they want part with??
Will keep a lookout for you Mr. N! ;)
Sent from my Nexus 5 using Tapatalk
Im pretty ews module and key dont have to be from the same ecu or even the same car as im pretty sure that you can sync/bind ews key and module to the ecu via a scanner of some sort. my cheap scanner has this option. I could be wrong tho, but a m3 specific ecu if needed, sadly people dont often want to part them from thier engines
The other option could be getting the ecu flashed to remove ews from system entirely.
Maybe give darren @ NZAD a call he might be able to import one for you.
Hi there
Cheers for the replies. I have already spoken to Darren and he is looking Into it for me.
I can get a set from the uk for about £250 but want to try here first.
As for the ews ideally we want t complete set so we don't have to worry about fiddling round with programming it to other ews chips ect. If I have to I will send one (when I find one) over seas to have the ews removed
Just run an aftermarket ecu with air flow delete and trumpets off the itb's :)
yeah we cant do that. for what we are putting it into we need to use factory parts
