brockie123 31 Report post Posted April 6, 2014 Hey, seriously looking into a few E30 coilover kits at the moment but cant seem to find the best price or anywhere local? i really like the look of the BC golds and have read only good reviews on there as far as bang for your buck. also megan racing do one which im pretty sure is identicle anyway. has anyone gone through this recently that could offer some help. i have the 45mm struts by the way. thanks. Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted April 6, 2014 Most of the kits cater for the 51mm struts, i went through the same thing in my E30 and i had the 45mm struts to being with. I ended up doing a 5 stud conversion and using E36 coilovers. It opened up my wheel options and gave me bigger brakes. It sort of blows the budget apart though. Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 6, 2014 Talk to Evan at Speedfactor, hes also a forum sponsor i think. They do XYZ for 45mm struts i think and you can send them to him and get them all welded up. Otherwise just get some 51mm struts and coilovers to suit and get them welded up yourself. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted April 6, 2014 You can use any of the struts, they typically chop the strut tube off and weld the coilovers onto the hub, which you need to have done by a certified welder who can certify the welds which you need for an LVV these days. Quote Share this post Link to post Share on other sites
brockie123 31 Report post Posted April 7, 2014 thanks for help guys. i found some BC golds in NZ cheaper than bringing in some through a member on here that helped me out. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 8, 2014 Ive got XYZ, and after only a year and not even 10,000km (car is mostly parked up) the rubber shock boots are perished and f**ked. I suspect other cheap coil overs would have similar problems. Other than that they have served there purpose. Quote Share this post Link to post Share on other sites
Speedfactor 5 Report post Posted April 11, 2014 We have a pretty complimentary range of setups for the E30. We keep 45mm and 51mm tube kits Unlike most other companies, we can tailor spring rates, shock valving, camber plates etc. We do a custom heavy rear spring to suit extremely lowered E30's and keep the rear geometry under control a bit better. We can do all the LVV stuff, welding corner weighting even!! Cheers Evan Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 12, 2014 We have a pretty complimentary range of setups for the E30. We keep 45mm and 51mm tube kits Unlike most other companies, we can tailor spring rates, shock valving, camber plates etc. We do a custom heavy rear spring to suit extremely lowered E30's and keep the rear geometry under control a bit better. We can do all the LVV stuff, welding corner weighting even!! Cheers Evan Have you got spare shock boots? Mine are rooted. Quote Share this post Link to post Share on other sites
Madhatter 0 Report post Posted April 27, 2014 (edited) You can use any of the struts, they typically chop the strut tube off and weld the coilovers onto the hub, which you need to have done by a certified welder who can certify the welds which you need for an LVV these days. You need to match the right sized tube. Most of the cheaper coil overs are tapered inside, so you leave 50mm on the bottom of the strut tube which slides inside of the bottom of the coil over and helps locate inside so it's largely centered. They aren't just welded to the stub axle, so size does matter. No problems using 51mm struts in a car that had 45mm ones, they all bolt up the same, so if you can't find 45mm ones, just use a set of 51mm tubes from a 323i or 325i and convert it over. BC also make them in a 45mm fitment for 4 cylinder cars. Only suggestion whoever you use, if you want the car low and still want to have any sort of suspension compliance, make sure you get ones which are base height adjustable. That way you can change the ride height without needing to compress the spring and shorten the shock travel. Edited April 27, 2014 by Madhatter Quote Share this post Link to post Share on other sites
YU4562 2 Report post Posted April 19, 2015 Anyone here know where i can get my front strut + Coiover welded? preferably a place where i can get LVVTA cert as well. BTW im in north shore auckalnd area Quote Share this post Link to post Share on other sites
