Lewis91 114 Report post Posted April 11, 2014 http://www.trademe.co.nz/motors/car-parts-accessories/bmw/suspension/auction-714411853.htm Has anyone tried these? Thoughts? Cheers, Lewis Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 11, 2014 Look pretty much the same as the ones I brought. Seem to work well, Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted April 12, 2014 needs a cert. sfactor do sell very nice products and are great to deal with.Get some camber and castor adjustable ones. Castor is goodWhy do you need more camber up the front? Quote Share this post Link to post Share on other sites
Lewis91 114 Report post Posted April 12, 2014 Not keen if I need to cert it. I want to use H&R springs and need to camber the front more so it tucks slightly. The rear is about -3 and I want the front at -2ish. The front has nothing at the moment. Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted April 12, 2014 I run them on the E34 for better turn in and increased traction, but whilst they are fine on smooth roads they're harsh and noisy on bad roads with rough seal, bumps etc. Probably going to get rid of them shortly. The Ireland Engineering adjustable type ones that use the stock strut mounts are probably better for std street car, they do raise the front slightly though, but i used to run them on my old E30 without issue. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 12, 2014 Just slot the mounting holes and use washers. Job done son! Quote Share this post Link to post Share on other sites
