Michael. 2313 Report post Posted April 29, 2014 If I take my original 3.73 open type diff... Remove the non LSD center...... Take off the 3.73 ring gear...... Bolt the ring gear to specs with loctite to my LSD center...... and put it back in the diff accordingly, would it all match up correctly to the pinion gear in theory or should it be 'adjusted' ? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted April 29, 2014 No... it would still need to be dialled in. I would use Diff Specs In Drury for this 1 Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted April 29, 2014 I use Kayne Barrie. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 29, 2014 I suspected so much! What would be the cost for such a rebuild? If I supply all the parts, including 4 new bearings for the output and input shafts? Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted May 27, 2014 I use Kayne Barrie. x2. Do it once, do it right. No rework required. Quote Share this post Link to post Share on other sites
