adams202 1 Report post Posted May 6, 2014 (edited) I'm removing the front strut from the housing - To remove the collar at the top I understand there is a "special" tool that I don't have. Before I butcher it - Is there a recommend way to do this that wont destroy the collar ? Thanks Edited May 7, 2014 by thirtyglam Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted May 7, 2014 I just use a plumbers wrench but make sure not to score the insert (the silver part) Quote Share this post Link to post Share on other sites
adams202 1 Report post Posted May 7, 2014 Brilliant - thanks. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted May 7, 2014 plumbers wrench here. works will. have only had one that it didn't work, and using a bit of WD-40 to penetrate threads and then out it came Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted May 7, 2014 Isnt it the same as some coilovers? eg use a flat head screwdriver to looesn the collar then unwind it? or am I high? Quote Share this post Link to post Share on other sites
