hugokan 0 Report post Posted May 13, 2014 Hi, I've done some research and people seem to bypass EWS and put the older Red Label 413 DME into their cars. However I am asking about the reverse: My e36 had a Red Label 413 DME and my friend has a Silver Label 413 DME (EWS) spare that I could use - will this work? Or do I have to use another Red Label? Thanks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2142 Report post Posted May 13, 2014 Hi, I've done some research and people seem to bypass EWS and put the older Red Label 413 DME into their cars. However I am asking about the reverse: My e36 had a Red Label 413 DME and my friend has a Silver Label 413 DME (EWS) spare that I could use - will this work? Or do I have to use another Red Label? Thanks i think you may be reading on USA based websites. from memory the silver type is EWS, so if you want to use silver type you will need to retrofit EWS in too. may get an insurance discount???? but otherwise not worth the hassle probably Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted May 13, 2014 (edited) If it's EWS-I you can bypass it by cutting a wire. http://www.bimmerwerkz.com/forum/286450-post3.html actually, it probably will work, if you put it into a car that doesn't have any EWS gear. Edited May 13, 2014 by antil33t Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 14, 2014 part number please. Quote Share this post Link to post Share on other sites
hugokan 0 Report post Posted May 14, 2014 (edited) Bosch Red Label 0261200413. The silver one has the same Bosch number. Chassis is JA91352. I was thinking the same as antil33t - that the EWS from the silver would have nothing to talk to anyway? Thanks Edited May 14, 2014 by hugokan Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 15, 2014 Part number is invalid .. have a look again. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 15, 2014 (edited) Part number is invalid .. have a look again. No it's not Josh... It's the Bosch part number. The BMW part number should be on the label as well though. The EWS DME needs to get a signal from the EWS control unit to switch. I suggest the OP puts in the correct DME Edited May 15, 2014 by B.M.W Ltd Quote Share this post Link to post Share on other sites
hugokan 0 Report post Posted May 15, 2014 Thanks Glenn Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 17, 2014 No it's not Josh... It's the Bosch part number. The BMW part number should be on the label as well though. The EWS DME needs to get a signal from the EWS control unit to switch. I suggest the OP puts in the correct DME Thats what im after ... the BMW part number .. I cant advise with out the BMW part number and I cant compare software types without it. The Bosch number is useless to me. So it still stands Glenn, the part number is invalid. Hugokan: Your welcome to PM me a photo of the label if you like. You should have a programming and part number label affixed to the top. Unless it has been replaced at some stage. If so youll be looking for a yellow label with "tauschteil' affixed on it. Quote Share this post Link to post Share on other sites
