Blackfrogg 1 Report post Posted June 3, 2014 As per title need getrag 240 from e30 320i. only need it for shifter linkages so it can be rooted. Thanks Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted June 3, 2014 You can cut and shorten your 318 linkages and join then togther not sure of exact length to remove but is about 25mm. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted June 3, 2014 ebay Quote Share this post Link to post Share on other sites
Driftit 2205 Report post Posted June 4, 2014 Kayne Barrie from Kayne Barrie motorsport will have all the parts you need. He rebuilds all the BMW E30 series cars 240 boxes. Is based up in Silverdale. Kayne - 0274 975 330 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted June 4, 2014 You can cut and shorten your 318 linkages and join then togther not sure of exact length to remove but is about 25mm. car will need to be certified if you do that no need if using genuine parts Quote Share this post Link to post Share on other sites
Blackfrogg 1 Report post Posted June 5, 2014 Cars being certed anyways due to the engine swap Quote Share this post Link to post Share on other sites
