Andre3000
WTB: Front lowering springs for 318 (cab)
Anyone got a pair of unwanted gangster thug unit bitchn super lows?
Need them for a mates 318i cab but any will work as long as not from a m20 engined e30.
Chur
Chur
you will want M20 ones as the cab is heavier and needs the higher spring rates.
It is not advised to put 318i springs in. All catalogues specifically say this.
All cabs run the bigger 51mm struts and suspension like 325i sedan and coupe, regardless of being a 318i.
Yes they bolt it, but not ideal, may cause handling issues etc
Edited by _Ethrty-Andy_
Can do different options.
Let's see pictures of your friend's vert!
Sent from my Nexus 5 using Tapatalk
