Herbmiester 946 Report post Posted July 3, 2014 I was hoping someone could give me feedback on using Powerflex RTAB in an E36? I read on the Turner motorsports site that they don't recommend this as it can cause binding. My E36 has factory motor sport suspension according to the BMW Vin checker and as part of the rear end rebuild I am also looking at replacing the rear shocks, probably Konis. I have some Turner shock top mounts with reinforcing plates. Car will be for enthusiastic street use. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 4, 2014 I ran them plus limiters - stupid and way too stiff. Just went back to M3 bushes and limiters - good setup allowing some movement. Quote Share this post Link to post Share on other sites
Herbmiester 946 Report post Posted July 14, 2014 Any suggestions where the best place is to get some limiters? Also does anyone in NZ do Meyle bushes? Quote Share this post Link to post Share on other sites
euroriffic 626 Report post Posted July 14, 2014 Miland do mylie bushes, check his trademe listings. I'm running nolathane ones and seems fine to me Quote Share this post Link to post Share on other sites
Herbmiester 946 Report post Posted July 15, 2014 7th Gear what make of bush do you use? Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted July 16, 2014 (edited) just do OEM RTAB bushes and limiters from M3_power. Ask nice, and he might lend you the bush removal/install tool. Did mine a month ago Edited July 16, 2014 by Beeker2 Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted July 18, 2014 The lateral limiters don't control fore and aft movement so you still get some toe change The Urethane replacement bush kit limits fore / aft and lateral which tightens up the toe dynamics I'm no expert, but poly bushes can also induce binding, not so much on a stiff track car, but potentially more so on a softer sprung street or rally car. Not ideal. Quote Share this post Link to post Share on other sites
