SIR E30 68 Report post Posted July 24, 2014 Couldnt find the gearbox section so here we go! Mods can move this if Im being stupid.. I dont know if what Im asking for exists.. I am in the process of putting a different gearbox in my E30, currently I have the old gearbox crossmember (from an auto) which I had planned to modify and mate up to the new box. The tricky part here is that now that Ive fitted the engine and box the new gearbox is significantly shortly and lines up with the front set of "tracks" on the body.. The existing crossmember fits only the rear-most set of "tracks" on the body. If anyone has come up against this or knows of a crossmember that fits the front tracks Id be thankful, it will save alot of time and cutting/pasting! It only has to fit the E30 body and line up in the centre of the tunnel, the rest is going to be cut out and made to fit the new gearbox. Thanks in anticipation. -Jason Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 25, 2014 Just make a whole new one, prob less stuffing around Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted July 25, 2014 I literally need to drill one hole in it and fit a nolathane bush and it will work.. So far research has lead me to believe that an E21 crossmember will work, now to find one! Quote Share this post Link to post Share on other sites
westy 614 Report post Posted July 26, 2014 Front tracks are for manual and rear are for auto aren't they? Pretty sure that's how it works, Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 26, 2014 Front tracks are for manual and rear are for auto aren't they? Pretty sure that's how it works, yep manual ones tricky to find on thier own! Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted July 26, 2014 probably have one, what are the bolt spacings? Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted July 26, 2014 Cheers Fullas Foxy you're a legend, I will measure up at the shed tomorrow and see what the numbers are. Quote Share this post Link to post Share on other sites
