Rob HB1
e36 318 heater control valve
Have now replaced heater control valve twice and still having issues.
First time right side blew cold and now only get heat in windscreen or demist mode.
Don,t want to spend some silly amount on a new control valve if something else could be giving trouble
Any ideas?
P.S had a manual conversion done at Hellbm.
Edited by Rob HB1
Make sure you've bleed the cooling system properly. This will require you to bleed with the heater set on hot...
Yes was done when installed both times
Have you tested it?
Heater worked for a couple of months first time round bit only 2 weeks second time.
Probably pay to put 12V across each of the value and see if they are working or not
