Rob HB1 90 Report post Posted August 6, 2014 (edited) Have now replaced heater control valve twice and still having issues. First time right side blew cold and now only get heat in windscreen or demist mode. Don,t want to spend some silly amount on a new control valve if something else could be giving trouble Any ideas? P.S had a manual conversion done at Hellbm. Edited August 6, 2014 by Rob HB1 Quote Share this post Link to post Share on other sites
Eagle 1546 Report post Posted August 6, 2014 Have you tested it? Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted August 6, 2014 Make sure you've bleed the cooling system properly. This will require you to bleed with the heater set on hot... Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted August 7, 2014 Make sure you've bleed the cooling system properly. This will require you to bleed with the heater set on hot... Yes was done when installed both times Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted August 7, 2014 Have you tested it? Heater worked for a couple of months first time round bit only 2 weeks second time. Quote Share this post Link to post Share on other sites
Eagle 1546 Report post Posted August 7, 2014 Probably pay to put 12V across each of the value and see if they are working or not Quote Share this post Link to post Share on other sites
